Cannot write changes using AS BUILT "Service procedure has been interrupted"
Trail_Runner
Me
MI
2021 F150, 97 Jeep TJ, 2022 Bronco
I have successfully changed tire size and used the 'plan English" programming to disable the horn beep when leaving with the key.
I cannot program anything using the as built sections. I tried the horn beep using as built and got the same error.
Ford Bronco Cannot write changes using AS BUILT "Service procedure has been interrupted" 4e
Running the newest Forscan 2.2.48 and OBDLinkEX firmware 5.6.24
Ford Bronco Cannot write changes using AS BUILT "Service procedure has been interrupted" 5e
I have a 2021 F150 and had no issues programming the AsBuilt.
Trying to change 730-03-01 023A to 003A to disable Auto Start/Stop. I get the checksum error and press OK.
Ford Bronco Cannot write changes using AS BUILT "Service procedure has been interrupted" 1e
Ford Bronco Cannot write changes using AS BUILT "Service procedure has been interrupted" 3e
I tried entering checksum manually (0038), I get no checksum error but still fails the write with "Service procedure has been interrupted".
Also tried the single write and write all options...no luck.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
I know they locked down a couple things for MY22 vs 21. Not sure if folks with a 22 have had luck with the auto start/stop programming. I ended up buying the eliminator.
i had troubles with a few items giving me that code until Forscan came out with the latest version. Maybe try deleting it and trying the previous version?
Trail_Runner
Me
MI
I had the previous version of Forscan and OBDlink firmware I had tried first.
Ducati1098
No problems with 22’s. Auto start stop disable, tire recalibration, global windows all works and my forscan is probably 2-3 updates old right now.
‘21OBX
90Bronco19
2022 bronco outer banks
You do have the license either the free or paid correct? It won’t let you do some thing without it. I’ve changed all that on my wife’s 22 with no issue.
Trail_Runner
Me
MI
yep. Currently the trial license.
JerseySierra
Brett
New Jersey
2018 F250, 2022 Bronco
Exact same issue here with Auto Stop Start disable.
BroncoMax21
Awaiting Wildtrak
It should work and seems like you know how to do everything correctly (and have done it before)! So this seems odd to me.
I have MY22 and the 2.3.48 release. Before that update, got auto start/stop to work (in addition to horn beep, driver side seatbelt chime). Needed the .48 in order to write properly and get the keyfob to control windows up though.
Either way, I'd just look over your process again, checking everything carefully....? Maybe reach out to FORScan support. Sorry I cant be more helpful.
DRC
Cedarpines Park, CA
22 Bronco
22 OBX built 6/16/22
I was able to disable Double Honk and add Baja
Unable to disable Auto stop and get "Service procedure has been interrupted"
Tried 2.3.48 and the last 4 versions for Forscan for Windows
Using Paid 1 year Extended License
Updated the firmware on the OBDlinkEX
Still no luck with Auto Stop
Any other thoughts?
Trail_Runner
Me
MI
So I have been able to use the as built for programming global windows and goat modes.
while programming global windows BdyCM section I did get the error when saving but it took the change.
still no luck with A.S.S.
may have to buy a separate ass eliminator.
DRC
Cedarpines Park, CA
22 Bronco
I opted to spend my money on the OBDlinkEX instead of the Eliminator device.
Gave me the option to make other changes.
Have already emailed Forscan about this issue, maybe they will be able to fix this.
DRC
Cedarpines Park, CA
22 Bronco
I have been in contact with Forscan.
They sent me a newer test version and I was able to disable ASS PSCM 730-03-01
You may want to wait until version 2.3.49 is released before buying the Eliminator
Trail_Runner
Me
MI
Thanks for the update.
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
Glad to hear the next update will allow PSCM updates.
kimmiemom64
Greenville, NY
2022 Ford Bronco
Where would I find the code change to disable the start/stop? I was going to disable mine today, but the code I have is for the 2021 and doesn't look the same as what came up on mine.
