Cannot insert fuel nozzle or the funnel
Lil Red Broncette
Explorer
I was asking myself the other day when filling up just what benefit is there to not having a cap? A few seconds? Inevitably whatever mechanism they have in the cap that lets air in but not vapors out fails and $15 cap is easy to replace. Can't imagine replacing the capless assembly is easy nor cheaper. Or is the case of the government doing us a favor by mandating capless under the rationale that with self service, us amateurs too often don't put the cap on all the way.
Automator59
Upland
'22 Bronco, F250 (7.3l), '23 Integra, RDX, Saab
I see this issue on the Acura Integra forums as well. Several people attributed it to Costco pumps stretched across to the opposite side, putting too much pressure on the filler and breaking them. I haven't had a problem with my Bronco, my Integra Type-S, or my previous A-Spec. I also had a Mustang GT for years and didn't have a problem, but I don't do the stretch across the vehicle to fill it from the opposite side.
AZ_Liberty
2007 Expedition
Having the fuel fill on the wrong (passenger) side is a serious pet peeve of mine. Immediately makes me want to buy something else.
AZ_Liberty
2007 Expedition
I’m aware, but never knew of an issue until the Bronco came along.
Me either, I guess the question is did Ford change the design for Bronco for some reason. I'll have to remember to look at the wife's F-150 to see if there are any obvious differences.
0ne
Nate
CO
Flex
Capless makes me fear miscreants putting detritus in my tank though you can buy locking plugs for some but haven’t found one for Bronco 🤨
Fetus1987
Pedro
Chicago, IL
Ford bronco outer banks 2022, volkswagon jetta SEL
Went to fill up last night and could not get the gas stations fuel nozzle all the way into the tank, gets caught on the second flap. Tried multiple nozzles at multiple gas stations and same thing. Tried the fuel funnel from the trunk and same issue.
Attaching a pic of the inside flap/door that the nozzles get stuck on- is there supposed to be a cover on it that broke off? Seems there are tabs sticking out of it and the top of the nozzles/funnel gets stuck on the bottom one. The other pic shows how far in the funnel goes, cant get it in any further.
Any chance someone can take a quick of their interior to see if it looks the same? I cant put gas in my bronco, which is kind of an issue : )
Did you take this to the dealer? What ended up happening? My bronco did this to me this morning. 😭
Boomhuck
C
Wi
2024 Outer Banks
Just happened to me as well with 1300 miles. Assuming this is covered under warranty?
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
EPA mandate. Doesn't have to make sense
Felix808
SRV CA
Well it does prevent the use of an Oklahoma Credit Card so there is that :unsure:
Ducati1098
@flip @Ducati1098
Any solutions? Just happened to me.
Did you try a different pump? Sometimes there’s an issue with one of the nozzles and it won’t allow the latch door to open.
If you’ve tried multiple nozzles and it still won’t work, there must be an issue with the filler neck itself. Unfortunately hard to say what exactly without looking at it.
MNBigfoot
MN
I managed to get it in, but had to give it a hard shove. I'll see what happens tomorrow, at a different pump.
