Can I do side stripes myself?
Glade Runner
Everglades
VA
Yes
Everglades
It seems like a laser level could be useful for this.
5GENIDN
Idaho
I would strongly suggest NO..... Never use a level when applying decals to a vehicle..... Vehicles, no matter if we "leveled" them or not, are NOT level.... (I do this for a living)..... Follow (parallel) the shadow lines or the pinch weld so that they "look" level. Leveling them to gravity (bubble level or laser level) will make them look not level/crooked even though they are level to the ground.
Glade Runner
Everglades
VA
Yes
Everglades
My laser level can be set “unlevel” just by setting the beam to cross two known points and locking it in place. I thought most of them could be used like that 🤷‍♂️
5GENIDN
Idaho
Had not thought of that... I always am using mine to hang wall decals and murals and window vinyl.... I want it level for those. I have had a couple of trainees that have wanted to use it for vehicles and .... NO..... tried to teach them how to match the lines of the vehicle... one issue with the vehicles is that you are working with multiple compound curves...
Nc211
Washington DC
Rule #1 of DIY, no matter what the project is you're doing.... you'll know. You'll know where the defect is. You'll know where the weakest part of the result is. It doesn't matter if you're putting on a sticker, hanging a picture, refinishing 4,000 of oak flooring...
Rule #2 of DIY, as long as others don't see it, it's perfect and you sir are a steely eyed missile man.
quickstep192
chas
Maryland
Bronco Black Diamond
Any thoughts on my color combinations?
Ford Bronco Can I do side stripes myself? AD7C8678-7C75-472A-9AA6-47653CF45B5E
Ford Bronco Can I do side stripes myself? 20B06D1E-28FD-4CE4-8989-4F3F0130E242
Bschurr
NY
I think I dig the red but would need to ask my wife to confirm that’s what I like - LOL!!
How about a thin red line on the outer edge of the rim as well?
MTjockey
Doug
Nampa, ID
2021 4-Door Bronco
quickstep192
chas
Maryland
I’m going to give it a go. Now, I have to decide which stripe to get. I’m leaning toward a stripe with a black background and a red 1/4” accent stripe. Anybody got that on a white bronco?
Q1svt
Sunny & Warm SoCal
2025 Badlands, Sas-sy Manual 2dr, # of fords
Or hay maybe just go for it... full retro? You do like RED.
These are a couple of bodacious broads, living life [they're well into their 80's] had custom work done to the new rig.
I'm sorry to report this has been done already to a Bronco…
Way to go …
Tim Barts w/Long McArthur Ford
Ford Bronco Can I do side stripes myself? IMG_6478
infinposib
Manny
CA
Camaro
"YOU CAN DO IT". I did my own vinyl hood stripes & rocker panels, which was a lot more than just a stripe. I just bought vinyl and cut it myself using knifeless cutting tape. Lots of youtube videos. First time for me and it wasn't too bad. I had to redo one of the hood stripes due to stretching the vinyl and causing a few ridges. Do not do it if the temp is hot (my mistake was trying to do it when it was 85 degrees)... it makes the vinyl soft and it can stretch easily. You can do it a couple of times if needed. The cost of a couple sets of stripes beats the quote you got by a long shot. Like stated, painters tape to keep things straight and after the first one the second one will go on easily.
These are hands down the best stripes I have seen on the Bronco. The colors are perfect together. Did you make this or modify a kit? It looks amazing.
56F100
john
Venice, FL
56 Ford F100 with 30K original miles
I do like the red stripe and red mirrors. I had a side spear placed on my 2023 Race Red OBX for $200 and a wide white side panel placed on my 2023 Area 51 BD for $900. Both done perfectly by Sarasota Wraps. Great
Ford Bronco Can I do side stripes myself? IMG_1286
Ford Bronco Can I do side stripes myself? IMG_0442
people.
