Can Forscan change trail cam settings (360 cam)?
sportcoupe
Georgia
2023 Bronco
Can Forscan adjust the 360 camera settings so camera stays on over 5 mph?
RedShiftWT81650
J
2014 jku
Everything Iā€™ve looked up has said that itā€™s a firmware setting that disables the trail cams above 5mph. I could be wrong but I havenā€™t found a forscan setting to change for it. ĀÆ\_(惄)_/ĀÆ
l88m22vette
IL
Please sir may I have locking diffs?
I wonder if it is the camera firmware, I know it "should" be accessible via CAN-Bus some way or another, but what if it's not? Maybe the camera receives passive information about speed and kicks itself off. If that's the case is should be possible to access the cameras.
I've also wondered this about the mirror lights for actually driving on a trail when its dark.
HotdogThud
mk6 gti, '21 MoarDoor
Not that I know of, but a lot of those speed-related settings can sometimes be disabled by not trying to set a maximum speed, but setting it to zero. (works in BMW-land, at least)
ScLeCo
Springfield
Charger Hellcat
Mine stayed on till 20mph. I got a can opener now it stays on at any speed.
Rydfree
Benny
Alabama
Just enable Baja mode and use it for unrestricted camera access.
^ This
Select Baja mode then manually select or de-select functions such as lockers,4WD modes etc as you wish.
helifino16
Ron
Mount Sinai, NY (Long Island)
Besides Baja Mode, mine stays on in 4L all the time as well.
(Not recommended for on road use)
vrtical
Doug
GSMNP, TN
Fords
^ This
front locker is not available in Baja, but you dont need that if your not in 4L rock crawling stuff.
AK SNO RIDER
Ty
Alaska
^ This
Except Baja sucks for most situations unless you really wanna drive everywhere at 4000 rpms.
mpeugeot
You can manually upshift the automatic into a higher gear. Baja is really not a daily driver friendly mode, so I do agree that it's not without sacrifice.
