DRL settings in Forscan
Beaver24
Missouri
2018 Juan Fitty
I toyed around with a ton of settings in forscan trying to see whats possible. I was able to get the amber DRLs with the headlights off but no luck with other settings. It looks like the spreadsheet is incorrect, since 04 actually sets the blinker to turn, DRL, and position, and its the position setting that appears to override the blinker and make them stay on full time. Right now the best option is Turn and DRL only, which I think was 03 if looking at the as-built.
Here is mine without headlights on.
I have 726-43-01 set to:
0101 amber when driving, turns work, white when headlights on or trans in park
0202 is white, turns work (stock)
0303 amber, no turns
0404 amber, no turns
I have a 21 big bend non-mid pkg w/signature headlights
0101 or 'Turn and DRL' is the only mode that works the best. As others have said, position lights take priority and block out turn signals.
I also installed the Stickerfab amber overlays.
How the hell is this working for you guys. Position/marker lights definately override turn signals.
Crash98
Viet
Bremerton, WA
2017 Ford F-150
I've got Wildtrak with lux package. I tried 0404 and it gave me amber bars but no turn signals when headlights are on. With DRL, it was amber and flashed amber with turn signal. I didn't like not having front turn signals at night. Tried 0101 and it was white bars like from factory. The spreadsheet needs to be updated because it doesn't work as written. I'll try the plain language change next.
BBSas
Alabama
Does "position" mean the side marker lights as well as DRL? "Position lights"
I have the halogen lights and would like to have only the turn signal/ parking lights only on in the drl setting. Do you know the setting for that in FORscan? 2022 Big Bend
Ducati1098
I think you mean the standard non-signature LED headlights. You can’t get halogen headlights on a bronco.
BBSas
Alabama
Taillamp Comparison - LED v. Halogen
Rank VI
Mar 10, 2021
Taillamp comparison of halogen lamps on a Black Diamond v. LED on a Badlands.
We have more photos in our Bronco Nation Photo Library.
Figured they were the same as taillight’s. Thanks for the info.
Ducati1098
No problem. Yes the taillights have halogen or LED. Headlights are LED for standard or signature lights.
darinhouston
Darin
U.S.
Toyota Rav4
When I use 0101 I get the same as you, but the ring is not very bright.
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Don’t bother with the as-built module, just go into the plain text BdyCM module and change “Right (& Left) Front Turn Lamp Usage“ from “turn only” to “turn and DRL”
darinhouston
Darin
U.S.
Toyota Rav4
I lik
Perhaps, though I like to know what changes it's making.
darinhouston
Darin
U.S.
Toyota Rav4
Could just go back into the as built module after and compare notes if curious
perhaps. But there’s no easy way to compare more than a known address. What if it changes multiple addresses?
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Didn’t say it would be fast or easy, just possible. I have a full printout of my stock settings if I ever want to see what’s different.
It’s just not that much of a change… just makes the center bar of the DRL’s amber when not in park and the headlights aren’t on. I haven’t combed through mine extensively but I’m confident there isn’t anything else that changed. My profile picture shows what it does although they’re more amber in person. Car is in neutral w/ parking brake set for the photo
darinhouston
Darin
U.S.
Toyota Rav4
Ford Bronco DRL settings in Forscan 8781812C-C8F1-4DF9-BD17-C84FA53D49E7
Looks especially good with the Hot Pepper Red. (And another badlands accent color)
wildtrakRUBI
2022 Ford Bronco Wildtrak
Any updates on this topic? I have a 22wildtrak and am also trying to get the amber DRLs with turn signal. Preferably that doesn't turn white at night or with any other reason.
Ducati1098
Not possible. Amber DRL’s will always turn back to white when the headlights come on.
