- Brandon
- Oct 5, 2020
- 49
- 606
- 1,495
- Utah
- Website
- www.puravidaoffroad.com
- a number of classics and my 4dr Badlands
- Badlands
I'm at Bronco Safari and there's a Forscan guy here so I had him check my previously set settings to see why my fog light indicator on the dash no longer works. After some changes, my DRLs no longer work and we're not sure why. ('21 Badlands Lux with an added fog light switch)
We checked the settings listed below, which I had enabled via this thread and some of them had been changed to "disabled" since I had previously set them - we assume a Ford update reset them.
Well, we made sure all of these were re-enabled, as well as playing around with "fog light usage" (BdyCM 726-39-01). As this was the only config I hadn't previously set, we tried a couple of different options here and the DRLs still don't work. Would any of these settings also disable DRL? Unfortunately, the Forscan guy at Bronco Safari didn't save anything prior to his changes, so I can't revert back.
BdyCM Configuration
Front fog lamps - change this to "Enabled".
Fog Lamp Switch - change this to "Enabled"
Using Front Fog With High Beam - "Allowed"
IPC
BdyCM (As-Built Configuration)
726-42-01-xxxx-xxxx-xxxx - Change the green value to 0101
BdyCM Configuration
IPC
