- Ken
- Aug 12, 2020
- 44
- 9,476
- 31,170
- St. Augustine, FL
- 2023 Outerbanks Bronco
- Outer Banks
Don't be too hard on yourself. Whether you admit or not, panic sets in and the best decision is only realized after the fact.Yeah, I think I have started it before rolling, but I wonder if the grade and/or loss of vacuum pressure or something else in combination prevented it from starting. The more I see these comments, the more I think I screwed up and simply should have made a different decision and I simply did not and made, while not the worst decision, I didn't make the best decision as it all turns out. Based on comments and common knowledge, I doubt Ford will do anything.
Independent of the actual stall/descent/crash. Your approach was all wrong with the initial line. When you high centered the first time, should have given you pause to rethink the approach and technique. You opted for the skinny pedal and hopped. At that moment the adrenaline was flowing. Opting to continue with the brute force of the skinny pedal on repeated attempts wasn't going to end well. The Hill could very well have claimed another tie rod.
Anyway, hope the insurance comes through for you and be thankful no one was hurt.
