FDHog
Frank
2023 Lariat FX4, 22 Road Glide ST
You ever consider putting one of these in your driveway?
Ford Bronco Bronco vs. Retaining Wall...Bronco wins! image-asset
EVH1994
Normally I’d park in 1st or Reverse. But on the Bronco I park in Crawl, since it’s the lowest gear. Not sure it would have helped on that steep of an incline, but it’s worth a shot when you get it back,
Bobby
Kansas City
Toyota Camry
Let me correct your response text: Motherf***er Kim, it’s not a car, we’ve been over this!
FDHog
Frank
The Bronco can move easier in the lower gears. You're better off putting it in one of the higher gears. Why do you think you "pop the clutch start" in first gear.
Arrowbear Rider
Marcus
Laguna Woods, Ca
Bronco, Triumph Thunderbird Commander 1700
What about the tie rod? The infamous tie rods?
mostfrantic
Hesh
Tennessee
2023 Bronco, 22 Ram AEV Prospector XL, stuff
I have a similar driveway and try never to park on the incline. There are times I have no choice though. I parked on the incline after a couple inches of snow once (didnt think I could make the hill from the bottom and not slide back into the retaining wall), woke up to go to work, and the truck was gone. Overnight the truck slid down the driveway to rest on the flat at the bottom. Missed the wall by inches...
OrangecrushBronco
Jeremy
Washington state
22 Bronco
All things considered that's a happy ending. Glad it wasn't worse. I do spy that you have the modular bumper though, rather then the capable.
bhb
N NJ
LOL at the text "Ur car just rolled down ur hill"
Very matter of fact. To the point.
BigMeatsBronco
Allan
2021 FE 2 door
This statement is completely backwards...(unless your talking ratio nubers, which your not) the lowest gear on your shift knob is gonna always have the most "hold" on a hill.
7th would roll with almost zero resistance and crawler gear will likely skid the tires as it begins to spin the engine. huge difference here.
I thought this was common sense 🤔, guess not.
FDHog
Frank
You’re right. Don’t know what I was thinking. Been driving stick for 50+ years and always in reverse or 1st.
