BuckWildOffRoad
Austin
Arkansas
Badlands Bronco, King Ranch F250, Taurus SHO
Well.... Where to start?
Just a little history on the Bronco.
A couple days after I got it we had our son, and brought him home in it.
Ford Bronco Bronco Truck Build 1748927424928-tm
After a few trips I did a small build and went to Colorado with Toyo Tires to get content for a new tire, the RT Trail.
Ford Bronco Bronco Truck Build 1748927725460-iw
Ford Bronco Bronco Truck Build 1748926941721-3e
Next I progress to do full ADV Fiberglass, this was the start of my broncos deconstruction....
I wanted to blend the door panels and fiberglass....
Ford Bronco Bronco Truck Build 1748926872178-jf
My Bronco Raptor showed up during this time.
Ford Bronco Bronco Truck Build 1748928865259-1
I figured, "Hey, I might swell do a few other things while I am making dust"
Ohhh boy,
Ford Bronco Bronco Truck Build 1748928903614-cc
Ford Bronco Bronco Truck Build 1748928946009-t
Ford Bronco Bronco Truck Build 1748928991068-cb
Ford Bronco Bronco Truck Build 1748929012899-i2
One step forward
Ford Bronco Bronco Truck Build 1748929076036-q8
Several steps back...
Ford Bronco Bronco Truck Build 1748929190452-n5
Building towards the vision...
Ford Bronco Bronco Truck Build 1748929505485-nd
Having fun, so I just kept going with it.
Ford Bronco Bronco Truck Build 1748929581707-o4
Ford Bronco Bronco Truck Build 1748929675764-bn
Progress was good, aaaaannnnd then we moved across the country for my job.
Ford Bronco Bronco Truck Build 1748929807842-pa
Ford Bronco Bronco Truck Build 1748930000325-o5
Another baby just a few weeks after we moved...
Ford Bronco Bronco Truck Build 1748930108661-kc
And I got a shop to work on my projects..
Ford Bronco Bronco Truck Build 1748930171727-d6
Well I got all this space. But so much time has past between what I originally wanted, and now...
And who needs two broncos? I already have a Bronco Raptor... What I am really missing is a truck...
Line a few things up...
Ford Bronco Bronco Truck Build 1748930571000-r3
And Viola!
Ford Bronco Bronco Truck Build 1748930606143-sn
Ford Bronco Bronco Truck Build 1748930647140-n8
Shoot... Now what? no turning back!
Ford Bronco Bronco Truck Build 1748930701284-gx
Measure twice, cut once, repeat..
Ford Bronco Bronco Truck Build 1748930774654-mu
Annnd cut some more...
Ford Bronco Bronco Truck Build 1748930814726-eu
Start welding in...
Ford Bronco Bronco Truck Build 1748930870546-hh
and weld some more....
(The roll bar is boron steel, to keep it structural I sleeved it with 10" of steel inside because you will loose strength when welding to the heat treated boron.)
Ford Bronco Bronco Truck Build 1748930916011-18
The key is you MUST make really detailed plans..
Ford Bronco Bronco Truck Build 1748930990139-oy
This is how she sits as of this weekend, we're finally building more than cutting!
Ford Bronco Bronco Truck Build 1748931078447-ot
Now, here is the plan, or as much of it as I can share... The plan is to do the full reveal at SEMA..
The bed will overall "appear" to be 5', however I am keeping 1' "inside" the cabin to house the electronics, sound system, and dry storage.
Wheelbase is around 117", roughly the same as a 4dr f150 short bed.
40-42" tires without rubbing.
Front will sit around 4"-5' wider per side and moved forward 1.5" for cabin clearance.
Front buckets will be cut out and custom towers made to support the long travel coilovers.
Rear is getting long travel triangulated 4 link and a wide axle to match front.
Rear frame moved up 4" under the bed area to allow more travel.
Custom 40gallon fuel tank behind rear axle.
The bed itself will be aluminum construction to help save some weight ( with composite bedsides)
The bed is not separate from the cab structurally, it bolts to the structure you see in the photos.
The entire body (bedside, tailgate, fenders, door skins, hood) is my own design ( I can't share that yet) and will be 3d printed to make molds and ultimately a composite exterior.
Full belly skids
Custom bumpers
Engine mods
Sound system ( I already did it and then I cut it all out when I chopped the rear)
Lots of other details but that will all come with time...
That's all for tonight
BuckWildOffRoad
BuckWildOffRoad
Austin
Arkansas
Reserved
BuckWildOffRoad
BuckWildOffRoad
Austin
Arkansas
Reserved
BuckWildOffRoad
BuckWildOffRoad
Austin
Arkansas
Reserved
BuckWildOffRoad
BuckWildOffRoad
Austin
Arkansas
Reserved
DewarT
Todd
I have built quite a few vehicles in my time and I wouldn't have the balls to touch this one! All the electronics, Boron cage, aluminum body panels... Good luck my friend! Definitively watching this one!
SierraBronco
This is certainly exciting. I recently had a couple renderings made of a 4-door bronco pickup but without stretching the bed. Well...it was not an appealing look. 🤣 It's possible to get it looking awesome but would require the work you're currently doing, which is beyond my abilities. Looking forward to following along and seeing the end result!
Iceman62
Tim
Omaha, NE
2024 Bronco / Sasquatch
"Holy Chop-Shop Batman" that's one large, and awesome transformation. Can't wait to see the end result & congrats on the family addition too. :D
Danielsand
Daniel
Idaho
'21 OBX SAS
This is nothing compared to some "builds" on this forum. Everybody and their brother is "building" Broncos here. I just saw a guy bolt a pair of dich lights on, another one put a sticker in the back.
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
Ohhh boy,
One step forward
And Viola!
Start welding in...
Full belly skids
Custom bumpers
Engine mods
Did you also document all the run-ins you had with your HOA???
Ninjak
Miami
Ford Bronco Bronco Truck Build 1748956851553-nf
Bschurr
NY
Looks like a ln amazing project and thanks for sharing. Subscribed for updates!
Ford Bronco Bronco Truck Build tmp
SierraBronco
This is basically the equivalent of PPF
