Bronco Team 2 door.
Bikeric
Tulsa
2022 Badlands LUX on 37's
Multiple folks are running 0 offset with success without cutting and trimming. Hopefully I’m one of them lol. Gonna try it out
On a Raptor Yes, but any other trim will rub in off-road situations, unless you also add a Body Lift........🤔
Many have tried 37's, but none that I know of have got it done without cutting something. The Team at Carli Suspension couldn't run 37's with King shocks without removing the inner fenders and making different flares. They found 0 offset made clearance issues worse for themselves so they use Sas wheels with +30 offset. 🤷‍♂️
https://www.bronco6g.com/forum/thre...teresting-steering-linkage.60650/post-1939231
I still rub the flares myself, so I am looking at going to 6112's with heavier springs up front (or a 3/4" body lift).
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Understand and thanks for the link! I was mostly going off of the following link - https://www.bronco6g.com/forum/threads/the-ultimate-37s-38s-tread.65684/ and reports in the “HOSS 3.0 Lift Options” thread
I won’t be rock crawling or jumping just moderate offroad and would be using a smaller BFG 37 from my Raptor which now has 39’s. Planning on going with RPG Collars 3”/2.25”
Bikeric
Tulsa
Just get it done so we can have more data points for the others to learn from (y)
I'm not sure if @Bmadda has a build page about his lift, but his Bronco gave me a "little man" complex in Moab.....
Gratuitous pic from top of Baby Lions Back:
Ford Bronco Bronco Team 2 door. RtcYxWZ
emkayw
mike
southern california
ford fusion
I didn't want to keep the OBX badges, and I didn't want to do the Bronco script again... so I went this route. They're on the small side, but I am pretty happy- I think they're a good alternative!
I agree. I put mine on the front pillars of the MIC top.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
I never did a build thread cause I just plain didn't think about it, but it was pretty simple...2" of body lift+2" of eibach springs on stock squatch suspension. Gradually doing the same w/the non-squatch, but even on a BL the squatch factor is there...the non-squatch always looks like "little brother". It was always the same w/Jeeps for me too..."hey, I could get another inch by doing X" and so on it goes!
NORCALGXP
Sacramento, California
2017 Raptor
Barny227
Brandon
Wy
2014 wrangler jk
A big milestone today. I picked up my 2 door Wildtrak and I got to update my profile.
Thank you to @ChaseG for making me aware of the $2350.00 rebate for the leather.
First addition was the orange beauty rings.
Ford Bronco Bronco Team 2 door. IMG_20230616_163422
ChaseG
Chase
Washington State
2023 Bronco, 2018 Subaru Crosstrek
Oh man, I'm so jealous. Mine just arrived via train and I'm waiting on the call... Congratulations and I'm glad I could help.
BigDaddySquatch
Tony
Madison, AL
2012 Toyota Tacoma TRD Sport
Ford Bronco Bronco Team 2 door. IMG_7723
Ford Bronco Bronco Team 2 door. IMG_7722
Picked the BaseSquatch up today!! 1” level at TCustoms
Jack D
Jack
Central New Jersey
05 Jeep Liberty 6MT, 93 Explorer 2dr 5MT
The combination of silver, gray and black looks fantastic! Are they the original Big Bend wheels? How did you blacken them?
Blaven
Pennsylvania
I'll get a picture or two of mine as proof I'm in the 2Dr club (for a little while), but right now it's still dirty from when it was delivered 8 days ago and I haven't driven it at all.
I've been trying to get to finish up the downstairs of my condo, so I've been doing stuff here and there, but mostly fixing the glaring issues it had from the factory.
It had a gap in the weatherstrip, on both sides, at the back of the removable panels where they meet up (at least should) with the weatherstrip on the clam-shell. I could see the inside of the vehicle thru them and my pinky fit perfectly in the gaps.
The panel alignment on the driver's side door, fender and hood was horrible, like how did it even leave the factory like this horrible. I'm a former auto body refinish & repair tech and I could've done a better job in my sleep with a hang-over.
To top it off, it also had a 3 inch rub mark with the primer showing thru on the leading edge of the drivers door from the gaps and alignment being so bad. Yes, that mark was on it's baby picture also (I magnified the image a little and there it was). The dark blue touch up paint gobbed onto it made me cringe, but luckily that rub mark happened before the clear-coat was sprayed.
This picture should give you a good idea of how far I had to move/adjust the fender to even up the gap. I could only fit .030 of stacked feeler gauges between the door and fender at the bottom and that was also with the bottom of the door tucked below the trailing edge of the fender from the factory.
I got the light wet-sanding done after these pictures and now I just need to do the touch-up spot repair. You won't be able to tell that blemish was there after I'm done with it. (y)
The door panel scratches look like it's from taking the door off and not using the rubber guards that come in the glove box kit. I had the same scratches in the same area from not using mine the first time.
