GregFoutz
Lux Sponsor (Level 2)
Greg
Mesa
www.foutzmotorsports.com
21 bronco, 21 ford Raptor
adamruiz2001
SoCal
Ford SVT Lightning
Any side shots so we can see the actual leveling?
GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
That looks great
BaseBlackCoupe
Geoffrey
Nebraska
2022 Bronco Sport and 2022 Bronco
When my wife finishes her masters I'll trade my base in and get a raptor.. I level/lift everything but idk, I'll probably leave my raptor stock.
Bronc69
Chester County, PA
Porsche 911, 2022 X3 (wife's), 2015 GTI (sold)
How does the collar affect the spring/shock function? You're compressing the spring to increase the ride height.
If the springs are progressive, doesn't that mess up the ride on normal roads and shorten the overall suspension travel when you're off-roading?
This doesn't make sense to me.
GregFoutz
GregFoutz
Greg
Mesa
And this is a good thing because.....?!?!?!?!?!? I'm not finding any issue with my rig being "unleveled"...
I like mine to be level and not down in the front. I think it looks better. Personal preference. if you are happy with your rig as is then run with it.
GregFoutz
GregFoutz
Greg
Mesa
the lower coil spacer block just adds a little preload to the spring to bring the height up. I didnt notice any real change in ride feel or handling characteristics. It sill rides great and feels like stock. it doesnt shorten or limit or change the travel at all. The only way you limit travel is if the spacer is so tall that you end up in coil bind. in this case we are not even close to coil bind. the spacer could be another nearly 2" tall before getting to coil bind on the front spring. and since we are not putting the spacer on top of the complete shock mount you are not letting anything drop out farther then factory intent so the travel numbers are the same.
GregFoutz
GregFoutz
Greg
Mesa
Will these work to level out the 23 Wildtrak with the HOSS 3.0?
I think it should but I havent been able to test fit one on that configuration. I dont know about the spring rate on the HOSS kit so this may provide more or less lift on that version. if you are local to the Mesa AZ area we would be happy to try and test fit on your bronco
RaceRedBronco
Trent
Mason Ohio
4 door Bronco Big Bend
Looks great! Is that Race Red I see??
GregFoutz
GregFoutz
Greg
Mesa
our bronco raptor is Code Orange actually
