Bronco grille light?
Offroadalliance
Lux Sponsor (Level 2)
Boston
www.offroadalliance.com
Weve sold a few and customers have really liked the quality and light output from these. Theyre fairly bright and the amber/white color options are nice depending on the headlamp choice you go with (if you change to aftermarket ones). Install is super easy and straight forward, just make sure the backing is very clean and use an adhesive promoter to help since its off the front of the vehicle taking all the "abuse" from the road and sun.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We sell tons of them. Ships free from us and you also earn rewards points!
https://www.4x4truckleds.com/putco-luminix-ford-bronco-led-grille-emblem-for-2021-ford-bronco/
We've even got a cool little POP display in our retail store to demo it to customers. Highly recommend you pick one up from us. You can select white OR amber DRL (both colors are built in)
You don't need adhesive promotor as this product does not attach with stick on tape. It actually replaces your factory emblem and bolts through the grill from the back. So it's very secure. It's also an officially licensed product of Ford.
OFF
Ford Bronco Bronco grille light? 1715188504474-cs
AMBER
Ford Bronco Bronco grille light? 1715188552414-mv
WHITE
Ford Bronco Bronco grille light? 1715188565060-57
Installation Video:
Tdub0527
Ted
Minneapolis
'21 Bronco Badlands, 2024 Rivian R1S
I have it and it looks amazing. Highly recommend 10/10.
Wathoff24
Wathoff24
Chad
Las Vegas, NV
2024 Bronco
Yes, it is pretty cool. How did you configure the wire out of the fuse box? They don't mention that in the instructions...it's a tight fit to close the lid.
Ford Bronco Bronco grille light? IMG_6268
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I’m shocked that nobody has come up with a grill that removes the “Bronco” badging and replaces with a thin light bar. Or modified the OEM grill to accommodate a light bar. I think that could look sharp and be functional. 🤷‍♂️
BroncoDymond88
New Jersey
'23 Bronco
Love these but be forewarned I’ve had to replace them twice as after a few months the BRO is not as bright as the NCO. Both times they replaced via warranty but not sure if they worked through the issue.
