Bronco Grille lighting Teaser !!!!!
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
Being Sunday, the day of rest, I thought I should give you a teaser of my Grille lights while your resting on the lazy boy watching Football......... :D
So, I have it done, just not mounted. here is a snip it for now.........
Ford Bronco Bronco Grille lighting Teaser !!!!! image2 (4)
Ford Bronco Bronco Grille lighting Teaser !!!!! image3 (1)
See below for additional Pics !!! mounting in the next couple days.....
On the Truck..... Scroll down to see the grille done !!!
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
Can’t wait to see it mounted. Did you build this yourself?
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
Might have saved me some time, but not money..... $200 for a set. I can make them myself, and I enjoy doing it, plus I can make them indestructible. Who knows what type of LED's are being used. Can they withstand harsh off roading, or being submersed?? I'd be very interested to know what LED's they have behind the covers...... That's why you can get a Rigid or Vivid Lumen light bar for $1800 or one from Amazon (same size) for $120..... which one do you think will last?? Food for thought.......
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Did you 3D print the opaque letters?
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
no, Cut them on a CNC. Tried doing them on a laser, but cutting the depth I needed distorted them, so did it on a CNC. You could do it on a 3D printer, but the material would have to be equal in all areas. After I CNC'd the letters, I sandblasted them to remove any hot spots from the LEDs. Led's that I used are good for 100,000 hours, so I shouldn't have to change them out for over 10 years !!! (by that time Ford will be on version 25.2 MIC hard tops.... :ROFLMAO:)
Panzer948
Bryan
Charlotte, NC
1981 CJ5, 2015 BMW M4, 2019 Jeep G.C. Trailhawk
Interesting project. I am going to watch for future updates. Overall, I think it's cool you can build them yourself and not have to purchase. I am also curious if you will sale your on set.
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
Grille done, just have to mount it..... it will work with the DRL's.
First couple of the back.... all wiring sealed from moisture, soldered, heat shrunk, and waterproof tape. No mold or mildew is getting inside these !! (and still room for air to circulate inside)
Ford Bronco Bronco Grille lighting Teaser !!!!! image2 (5)
Ford Bronco Bronco Grille lighting Teaser !!!!! image3 (2)
grille from the front.....
Ford Bronco Bronco Grille lighting Teaser !!!!! image0 (8)
and with all the lights off in the building.... matches the DRL light almost perfectly !!
Ford Bronco Bronco Grille lighting Teaser !!!!! image1 (5)
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
Updated. selling them, I don't know...... I will think about it over the holidays.
Bschurr
NY
Panzer948
Bryan
Charlotte, NC
Cfield90
South FL
21 Bronco/22 Escape/01 Softail/90 Bronco (former)
Very nice!
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
That's really impressive.
Almost wondering if it might even be too bright for grille accent lighting - hard to gauge in pictures.
RoLyMa27
Rodney
SloKart, TX
21 Bronco, 22 Maverick
You get what you pay for!!!
