Fog Lighting within the Big Bend/Outer Banks/Wiltrak/FE grille design
GRPinehurst
Pinehurst, Texas
2022 Ford Bronco Outer Banks SAS
I'm going to assume aftermarket will have an option to mount fog lighting within the large openings of these grilles?
My current build is the Outer Banks with the standard bumper. Given where I live, we have an abundance of hazy misty mornings. Without exchanging out the lower fog lights in the standard bumper, what will be my options with adding fog lights within the gaps on the grille? Then would you wire to the existing power supply or the Aux switches?
I like the look of some of the lighting options within the Ram truck grille kits. I'm not interested in mounting pod lights near the exterior mirrors nor top. I'm not against removing the factory fogs but just thinking out loud.
Thoughts?
Used2jeep
Massachuvian
2007 Crown Vic P71
Thoughts?
IMO fog lights up top are near to useless due to the beam pattern (wide and low). Up top you would want driving lights (spots).
Not sure if I would put lights in the actual grill A) it's plastic and B) the criticality of the radiator/intercooler.
My plan is to go pod style on the bumper.
jaruss01
NJ
Damn, just dropped the word 'criticality'.... I think i need to read more.
