Bronco Grille lighting Teaser !!!!!
Gtrekker
Gary
NJ
Rivet nuts, nice... Definitely more secure than 3M adhesive. Going to order a kit, what size worked for you? Thanks...
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
I used both #6 and #8 screws. Mostly #8's, but had to use two #6's in the "C" at the ends as that's all that fit. Not going anywhere. I silicone them also, for extra waterproofing. I have a habit of over doing it, but at least I know they are secure.
Gtrekker
Gary
NJ
Oh pls.... theres no other way, right!!! Still wrapping my head on the rivet nuts. Did you actually compress them? I was thinking using the wide end to glue to the letter, inserting into the grill the secure with a bolt.
Sorry about being a pain, texting is tough. Just want to learn from ur experience...
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
Did not compress the Rivet nuts, just glued them in. Once you put it through the grille and bolt it in place, it holds great. Just make sure to seal every letter so no moisture gets in there.
Gtrekker
Gary
NJ
Nice!!! That what I was thinking. It should be a perfect fit. Thanks for the idea!! 👍👍
hollapm
Paul
SoCal
2021 Bronco First Edition, 2021 Ranger, 2024 F250
Grille done, just have to mount it..... it will work with the DRL's.
What wire did you tap into so that they work with the DRL's? When you tapped into it did you use a relay or just directly into the DRL wiring for power?
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
Used the #6 Toggle switch to wire up the grille lights so I can turn them on and off when I want to. The wires are already there under the hood, so it was easy.
