Badlands Grille Marker Light Decision
Cactusjk
Woodland Hills, CA
2023 BL 2 Door, 2007 FJC
Been looking through the threads and am trying to decide between SPV and the BroncoLEDshop. Not sure if I want to connect to an upfitter switch, into the headlight harness or fuse box. Sounds like you need to make a slight mod to route the wire into the fuse box. Welcome any recommendations.
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
I have the SPV grill marker lights. The wiring harness is worth the price alone. Easy to install. Wiring harness plugs into the OEM head light harness. So the behavior is like the Raptor OEM lights. Great quality. Smoke lens look is good. Light quality is better than cheap Amazon ones. One of the SPV lights developed condensation right away and they shipped me 3 replacements immediately. I’ve used one and it’s held up for over a year. Their products are excellent. I’ve bought 3 as a result. And the install video is also excellent
OracleLights
New Orleans, LA
www.oraclelights.com
These bright pre-runner lights give the front end of your vehicle a vibrant look that makes a bold statement on any vehicle. The included wiring harness reduces installation time and features offset cable lengths to make cable management easier. Style your vehicle with pre-runner lights that are practical and unique for the ultimate customized look!
https://www.oraclelights.com/produc...re-runner-style-led-grill-light-kit-new-style
Cactusjk
Woodland Hills, CA
Decided to go with the SPV.
RCR
Rob
Baltimore, MD
2023 Bronco 4dr Badsquatch
I purchased a set of grille lights from LEDFactoryMart.com that are great (link below). Shipping takes some time, but I like the lights a lot because they're a little more substantial than others. The kit also comes with a fuse tap to allow you easily double up an existing fuse. I used Fuse #22, the 360 camera module fuse, and it works great. Install did not require any mods. Really plug-n-play with the fuse tap. I was also able to securely close the fuse cover without really compromising its integrity.
https://www.ledfactorymart.com/prod...ater-ford-bronco?_pos=13&_sid=517b4a9d7&_ss=r
