Driving around on 4H on the pavement is very bad. Driveline bind, etc. Always make sure you are in 2H before you return to paved roads.
Except there are now a bunch of us that know of your error. How willing are you to buy our silence? Hmmmmmmmmmmmmm!!This will void your drivetrain warranty. Damage caused by running in 4h or 4l on pavement is not going to be covered. You can cause significant damage to the axles and transfercase. If you ever need any warranty work you should never mention you made this mistake.
The bronco isnt really different from most modern vehicles.. This works the same way my 2011 ford f350 works.Turn knob to put in 4 high or low.Ok ok it makes perfect sense. I knew about 4H vs 4A, just didn't think about it at the time. I come from a Land Cruiser which is full time 4wd and this isn't even a consideration...unless you do something stupid like leave the lockers engaged. FWIW I've been doing this a long time, know exactly how 4wd works, low/high, locking diffs, etc. But this is an area where the Bronco works a little differently from traditional 4wd vehicles. I won't forget it again.
Note to self. Never, never buy a used bronco.
Not true. The Bronco works exactly like a traditional 4wd vehicle. Which is why it was binding on dry pavement.But this is an area where the Bronco works a little differently from traditional 4wd vehicles.
This is the first Ford I’ve ever owned so it’s different for me. Most 4wd vehicles I know can be driven in 4H without binding. Having a separate 4A is different.The bronco isnt really different from most modern vehicles.. This works the same way my 2011 ford f350 works.Turn knob to put in 4 high or low.
Bite me.LOL this is a great troll job by OP.
Don’t worry, you’re not worthy.Note to self ... Never buy 8cam's bronco
