Broaddict trail deck installed
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
I’ve seen other reviewers where people just replace the pullout handle with a soft grab handle to make it fit with existing tables. Now I remember. Been awhile since I read or watched in YouTube.
While I think that helps with some, I don't believe it will solve the problem with all tail gate tables. I don't think it will work with my Broaddict tail gate table. I found it odd that it isn't compatible with the pre-existing Broaddict tailgate table.
Run3gun
Anthony
2023 Bronco
I totally agree my table Molle table was too thick that right corner bumps out just an inch too much . They should offer a huge discount to anyone that bought the first gen table that wants to add the slide
EOD98
Las Vegas
2025 Bronco Badlands Sasquatch
As requested. Here are some shots of my Broaddict TrailDeck and shelf. You can see that I used boat decking (peel and stick on) to cover my sound deadening and to give it a nice clean look.
Ignore the amps in the cargo floor. I just started an install and haven’t made a proper amp board. I have a Musway M6 Pro DSP mounted to the underside of my rear drivers side seat. The person plug popping out from under the rear seat is a quick disconnect for my downfiring sub enclosure. I wanted a simple option to remove it and not leave bare speaker wires laying around.
Ford Bronco Broaddict trail deck installed IMG_4711
Ford Bronco Broaddict trail deck installed IMG_4714
Ford Bronco Broaddict trail deck installed IMG_4713
PWillette
Parrie
Maine
I wish Broaddict would come up with an updated design which is 1 to 1.5in shorter to allow compatibility with existing tail gate tables.
^This^...shorten the deck to flush where the handle mounts and it would work with just about any tailgate table. Probably done intentionally so they can sell more of their tables.
Also, IMO the handle is useless...when I pull out the deck or drawer I simply unlatch both sides simultaneously and pull. Makes no sense to me to unlatch and then use the handle.
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
Is that the BroAddict floor liner for the TrailDeck?
EOD98
Las Vegas
No, it’s boat decking stuff I put in myself. Cheap and easy.
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
I wish Broaddict would come up with an updated design which is 1 to 1.5in shorter to allow compatibility with existing tail gate tables. I would buy one immediately, but can't justify losing my existing table ($250) then spending to $$$ buy this version and another tail gate table. Odd that they didn't consider this during the initial design. There are likely others similar to me.
As a matter of fact if you search here you’ll find that when they were discussing it there were some of us that pleaded with them to make it usable with their previous tailgate table (that I own). I feel the same way I don’t want to pay to replace it with one that fits the new table just to be able to buy the table. Maybe someone else ll come out with one that fits.
cactusgray
SoCal
2023 Bronco Wildtrak
Has anyone installed this with a tailgate subwoofer?
broadicustomworks
Hanging Rock, North Carolina
If it is 1.5" or less total depth and you remove the handle from the TD, it would work.
So, sounds like a "no".
TXAstro
Everglades
Trevor
Bronco Everglades
Everglades
I installed traildeck yesterday replacing the Ford pullout that was standard on the Everglades. Product seems really solid and used the foam from packaging for initial drawer liner. Initial thoughts this is great product for organizing storage and adding the convenience of the pullout deck. Easy install and no rattles. The drawer is limited in height but good for hand tools, recovery gear, or other. Will be testing it out in CO in one month.
Ford Bronco Broaddict trail deck installed image1a
Ford Bronco Broaddict trail deck installed image2a
Run3gun
Anthony
2023 Bronco
Looks Great ! Mine came with the drawer liners
Run3gun
Anthony
2023 Bronco
Never mind I see what you did with the foam
Wow looks amazing had to zoom in lol
TXAstro
Everglades
Trevor
Bronco Everglades
Everglades
The packing foam is perfect till you want to put something new in the drawer :crackup: I saved a sheet just in case. Will keep the right side open for general items. It's nice to still have the storage box below accessible. With the everglades pull out deck that was hard to reach. Now I can store safe jack below and hope that when in need will be able to pull the deck out.
CalvinT
Calvin
Phoenix, AZ
