BRAPTOR WHEEL OFFSET
Braptor P
Aurelio
Bay Area
Hello B6G Community
This post is specifically for Bronco Raptor owners.
I plan on new KMC bead lock wheels on my 23' Braptor. I am going for 17"X8.5 or 9 wheels and 37x12.50 possibly 13.50s, does anyone have any photos of their Braptors with a 0, -10, -12 offset? I want to see what each offset/tire combo looks like with the fenders. I prefer flush, a little poke is ok, thanks in advance.
swamp2
swamp2
Toyo Open Country M/T 37x13.5x17 on Method MR304 17x8.5 Offset: (mm)0 / Backspacing (in) 4.75
The OP was asking about Raptor, in the Raptor forum section...
Killer-Bimmer
WA
'25 - Bronco Raptor Shelter Green - '21 - F350 CCLB Antimatter Blue Black-out
Hello B6G Community
Did you decide on wheel offset yet?
I just purchased a full set including spare for my winter setup as lots of driving in the winter over our passes so always run full snows. Everyone always thinks I’m nuts, but haven’t found an AT tire that out performs a dedicated snow tire, but I digress…
I went with Method 703’s in Matt black +25 offset. The following is based on the calculator, and Nokian 315/70/17 Hakkapeliitta LT3’s. I’d play around as a 0 or negative offset is going to poke a lot as factor is +34.
Ford Bronco BRAPTOR WHEEL OFFSET IMG_7174
Ford Bronco BRAPTOR WHEEL OFFSET IMG_7175
Braptor P
Braptor P
Aurelio
Bay Area
Hello Killer BImmer,
I went with KMC impact forged beadlock 0mm 17x9 wheels and nitto trail grappler mt tires 37x12.50r17 I will post pics later in case anyone else want to get an idea of how my specific setup looks like. I couldn’t be any more pleased with the results. It does have a bit of a poke but not much.
budnr22
VA
22 Badlands
17x8.5 - 0 offset
37 x 13.5MT
Ford Bronco BRAPTOR WHEEL OFFSET IMG_1187
Ford Bronco BRAPTOR WHEEL OFFSET IMG_1185
Ford Bronco BRAPTOR WHEEL OFFSET IMG_1178
Jermd21
Jeremy
Bulverde, TX
2013 F250 4x4; 2013 Expy 4x4; 1984 F250 4x4
17x8.5 - 0 offset
37 x 13.5MT
Budnr22,
Great looking Bronco. Do you have any lift or suspension modifications? Experiencing any rubbing at full lock? I have 17x9 +18 RTR wheels and would like to run 37x13.50 tires as well. Thanks.
budnr22
VA
22 Badlands
Budnr22,
Thank you. Suspension is all stock. No rub at full lock. I have yet to have any rubbing at all.
Ford Bronco BRAPTOR WHEEL OFFSET 20250927_141013
