Borla exhaust or AWE ?
Caleb@PandaMotorworks
Caleb
St Louis MO
Does Borla ever get discounted like this?
They do not :(
At least don't pass their deals down to us vendors. They might do something themselves on Friday, but wouldn't hold your breath
GI_Jo_Nathan
Jonathan
I've been considering the Borla too.... wondering if the 'S-type' system is just the Touring without the 2nd resonator in the rear. Suppose I should give Borla a call and ask them.
It would be a nice feature if one could just add/remove the 2nd unit to change the sound.
I assume you are referring to the Climber version? If so, the difference is the actual muffler. The second rearward muffler is a separate add on item. Check out the system instructions and you can see the different part numbers for the included muffler.
This is the main reason I went with the Borla, on top of having them on several vehicles in the past. I have the Touring Climber, and wanted the option to add the rear resonator if needed. I didn't need to add it. With the S-type I may have wanted it.
Luckily it worked out because I wanted to free up the room where the stock muffler is.
GI_Jo_Nathan
Jonathan
I bought mine discounted slightly from ebay. They have the climber systems right now for around $715.
OVRLNDR
Joe
BLM
Borla provide any dyno data on HP gains with their climber systems?
OverlandingPastor
Louisiana
2012 Wrangler
I have it narrowed down to the Borla S or the AWE dual tip. Your getting a lot more stuff like pipes with the AWE. What about the performance claims ? The sound seems fairly similar in the videos. Please weigh in.
@Machinepirate , did you pull the trigger on one of these?
Bellime
Keith
2022 Ford Bronco
my Borla S-type dual black tip.
Ford Bronco Borla exhaust or AWE ? IMG_1695
Machinepirate
Machinepirate
Bronco, BMW X5
Machinepirate, did you pull the trigger on one of these?
I just finished the install on the AWE car back single tip. Sounds good but early. I’ll report in a couple days. The instructions were fantastic and easy to follow. I went with the single tip because I figured it would quicker to change out to the high clearance tip for off roading.
Ford Bronco Borla exhaust or AWE ? IMG_9969
Bellime
Keith
2022 Ford Bronco
Machinepirate
Machinepirate
Bronco, BMW X5
Thank you Machinepirate
Pastor, Day 2. I really like the exhaust. I have plenty of air flow now between the K&N intake. This was much easier install than that ! Their download instructions were great. Make your life easier and buy a pair of exhaust hanger pliers. The exhaust sounds great on startup and idle. When you get on it, nice and loud like a rocket. Minimal drone at cruise, i wont say none but tolerable. These are trucks. Youre not in a caddy.
OverlandingPastor
Louisiana
2012 Wrangler
That's great to hear! It will tone down a bit as it breaks-in also so the fact that you already like it is a good sign.
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Hey there!
We ran the AWE exhaust on our 2.7L FE and thoroughly enjoyed the tone and volume. We ran the dual exhaust option and AWE has multiple routes (single/bashguard vs dual). The choice on tip option is purely subjective!
Check out all of the options here:
https://www.lethalperformance.com/search/?q=awe+bronco
Check out our video here:
Let us know if we can assist!
