Body Control Module Fuse Box Location?
CO-Bronco
CO-Bronco
Canada
www.instagram.com
2021 - 4dr - Cyber Orange - Badlands
CO-Bronco
CO-Bronco
Canada
www.instagram.com
Are the all "Micro" type fuses or Minis? Can't tell.
Mattbar1
Mattbar1
Truck
I can not say if they are micro or mini but some of them are two in one...the wider ones.
Mattbar1
Mattbar1
Truck
My initial testing shows that the Spares that are titled "Not used (spare)" have continuous power from the battery....
Except 35, 17, 18 - These 3 are powered when the Ignition is ON.
You saw it here first!
I plan to use Fuse 4 for Battery Power. Fuse 35 for Ignition ON power.
CO-Bronco
CO-Bronco
Canada
www.instagram.com
Oh heck yeah, you da man.
AK SNO RIDER
Ty
Alaska
Look at that. Mystery solved. Good job guys. I can rest easy knowing I won't have to spend 10 minutes looking for it when my Bronco shows up in 3 months 🤣
Mattbar1
Mattbar1
Truck
Just wanted to report back that Fuse 4 for Battery Power. Fuse 35 for Ignition ON power worked well for the BlackVue Dash camera I am using.
Jb7
Woodstock ga.
Ram 1500 sport
ordered a mirror power wire tap
For my radar detector, anybody know which of these wires is power and which is ground (the wire tap has small flat metal blades that slide in these holes to tap the power source without any soldering etc…..
Ford Bronco Body Control Module Fuse Box Location? ED70D0F9-7F79-485C-BEEE-B669B9F44760
Vito
Victor
Rockville, Maryland
1967 Bronco
Hey Jeff, did you ever figure this out? I'm working with a Valentine Radar Detector and need to hardwire it and wondering where and how I want to hook it up. Thanks!
Mattbar1
Mattbar1
Truck
How did you pop that panel off? Just pull? I think I popped a fuse for the license plate light and am hoping it’s in there.
Yes pull it down from the top. It is hinged at the bottom.
