- Thread starter
- #1
I noticed my blinker stem is making a metallic rattle when it returns to the middle position. Sounds like a spring. Still operates normally, but my concern is it failing in the future. Ran multiple searches on the forum and couldn't find anything posted.
Update:
Video posted. Went to a Ford dealer after my hood ripped my 2nd wiper cowl off and showed this at the same time. Service advisor couldn't hear it (naturally), but we did check another new Bronco to see if this was a characteristic, and it's stem was nice and quiet.
So, appointment next Saturday for them to rip my cowl apart to diagnose why it doesn't clip down correctly and to take my steering column apart to review the switch. Then order parts, then rip it all apart again to replace any parts.
Update 7/23/23:
Blinker switch was ordered. Service advisor/Tech didn't listen to me when I said the cowl needs held down before raising the hood. The hood grabbed the cowl, mangled it further, and tore+wrinkled the clear bra. Tech blamed the issue on the hood being out of adjustment, being too close to the cowl and adjusted the hood forward, unnecessarily. Gaps between the hood and tie downs on the hood are now really close and the gap between the cowl is now large. The issue is that the cowl isn't properly clipping into the cowl housing, not that the hood is too close. SMH. Another cowl was ordered and I have little confidence they're troubleshooting the right issue. I left the dealer with more headaches to deal with.
I know it's minor. It's the moral of it all. I don't offer suggestions for fun, I do it to help and be preventative. This is why I hate taking my car in for service.
Update 8/9/23:
Dealer replaced entire cowl assembly. It appears I was right. The housing that the cowl clips to was the culprit. Blinker stem replaced and now sounds normal.
I had quite the debate with the service manager regarding the damage to my hoods PPF. Everything was to blame, except the neglegence of their advisor and/or tech for ignoring my advice to hold the cowl down when opening the hood. It doesnt matter what events lead up to the point of the tech forcing the hood open, that single event caused this problem. In the end, it'll be fixed and handled, and the manager still thinks they're "taking one on the chin" for me by covering the repair.
Oh, and Ford closed my case apparently. Good to know they considered the problem resolved before resolving the problem.
Update:
Update 7/23/23:
Update 8/9/23:
