BILSTEIN SHOCKS Destroyed
userdude
Denton, TX
2023 2dr Badsquatch
Are you sure this problem is limited to the 21/22's? Have not seen anything about any improvement/change from Bilstein on the 23's and later.
No idea, that's just the ones we've been seeing. I assume mine will bite the dust soon enough.
mpeugeot
I found my problem today, the top of the shock went right thru the frame.
Ford Bronco BILSTEIN SHOCKS Destroyed IMG_20240709_190554064_HDR
How the f' does that happen!?!
mpeugeot
Near as I can tell MB3Z-18A161-A BRACKET (18132) failed.
I guess that Ford will say the shock is "good", actually, I think the shock must have failed in a way that over extended it.... It makes no f'ing sense.
ScLeCo
Springfield
Charger Hellcat
I don't think I've ever seen something like that happen without a jump being involved. Crazyness.
mpeugeot
0 jumps. I have been all highway for the last 10k miles plus. I did get new tires, I bet Ford will blame it on the tires.
Hkak45
K
Illinois
21 Bronco Black Diamond
Yeah, 25yrs ago, the KYBs that came on the isuzu Vehicross (1st OEM to use remote reservoir) were far superior to the junk ford gives us...My Vehicross had 300,000 miles on OEM shocks with zero issues.
What are you running on your bronco now?
TopRecon
2021 2D Basesquatch
I'm dealing with this same issue right now, 27,000 miles currently and the reservoir rusted clean off the rear strut, and because it's missing my local dealer is saying the damage must be impact-related (I've had no collisions) and is refusing to warranty. Going to try taking it to another dealer to see if they offer a different answer, but it's pretty frustrating that they're worming their way out of covering a clear manufacturing defect.
@Ford Motor Company is there any way to contest a denied warranty claim for a defective part like this?
Ford Bronco BILSTEIN SHOCKS Destroyed IMG_9979
Haelous
US
2016 Mustang GT, 2023 Bronco Wildtrak
Open a ticket w/Ford Corporate and plead your case. That is your best bet until there is a SSM or TSB on this.
2023bronco
location
vehicles
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
'21 2 Door Badsquatch 40,000 miles, no leaks, no missing reservoirs, pretty good for faulty shocks I'd say! lol
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
There was an issue with early production, Wildhorses had a video on it but all those dudes are extremely hard on their Broncos.
V1Rotate
Brevard, NC
2022 Wildtrak
If I remember correctly it had more to do with a production issue causing rust to form in the joint and eventually cause the reservoir to fall off than it did with how it was used
