North7
North7
North Texas
SUV
has anyone seen how they attach to the control arm ? they look similar to 6112 bilsteins for the F150 and those have an adjustable spring seat
Here you go, but the if there are snap ring adjustments they do not show.
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences FordBronco_parts_09 - Copy
North7
North7
North Texas
SUV
Here is a side by side view of the two different style reservoir mounts that @Pittguy was able to get photos of. Best guess these were early Engineering Development units used in test when they were trying to determine the best configuration.
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences Bilstein Hi vs Low Mount Reservoir
Itchysquatch
Luke
Vermont
99 4runner, 2014 E class
Nice digging! What do we think, same shock different spring/perch? Or same shock same spring with just a different perch?
Itchysquatch
Luke
Vermont
They look like they are mounted in the same location but the reservoir is just inverted. These remind me a lot of the 5150's they use to make & were a great shock although the internals are different.
Have these on my 4runner, rides beautifully!
Although, after ten Years of road salt and off road use, the shaft on one just snapped last week.
North7
North7
North Texas
SUV
In reviewing the photos again I see we do actually have two confirmed sets of part numbers now.
The first set of part numbers are from @618TRVLWILD
Bilstien P/N: F4-BE5-M970-W6
Ford P/N: MB3C-18080-ARJ
TBD P/N: 202660079
The second set of part numbers are from @Pittguy, note the differences from above:
Bilstien P/N: F4-BE5-M968-W7
Ford P/N: MB3C-18045-ARH
TBD P/N: 203500325
Rebel Bronc
Central NY
'23 OBX, 2dr, V6, 4.27
I wonder if you cut a cross section out of those Bilsteins, you'll find a Fetzer valve, ball bearings, gauze pads, 3-in-1 oil, and 'bout 10 quarts of Prestone anti-freeze........no; make that Quaker State.!?
Look at the filth and muck on that windshield!
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences 1617977068493
vrtical
Doug AI
GSMNP, TN
Fords
I made a reference to F150 leveling kits that are widely used that Bilstein developed which have a snap ring range. It would not shock me if Ford went this route from the factory, it soo simple to set height. Snap ring grooves on shock body provide up to 2.75"
dgorsett
colorado
F250, Mustang, Explorer
Interesting comment by itcysquatch about perch. Pittguy 1 seems to have a higher perch than pittguy 2. Maybe that is the difference from BL to Sas? It seems perch would be an easy way to get a little lift?
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Need to start getting pics of the spring tag part numbers too.
North7
North7
North Texas
SUV
Any of these help? Outer Banks from today’s event..
Thank you, looking at the front, since it has the full part number, here is what we have:
@mtap photos:
TBD P/N: KB3ASY 00034
TBD P/N: 210126A
It is a partial match to the @Pittguy photo
TBD P/N: 203500325
So we can see the standard B-OB shocks share the same Ford base number as the BL, WT, FE and Sasquatch, however, those have have the added -ARH to denote the reservoir body shocks.
North7
North7
North Texas
SUV
If the Bronco had Snap Rings grooves, like the F-150 you mentioned, we should see the snap ring grooves on the shock body, are these visible on the F-150 kit your speaking about?
If the Bronco had them, we should see them but they are not visible. Here are a couple views for discussion. When you look at a Bilstein with Snap Ring Gooves they are on an Aluminum Alloy body with machined in grooves. The yellow Bronco shocks are pressed steel so no grooves. Are the F-150 kits like the yellow or silver shocks below?
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences bilstin-struts
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences Hidden Snap Ring Grooves
ac360
Here/There
None
@mtap photos:
TBD P/N: 210126A
TBD P/N: 203500325
Would it be wishful thinking: "ARH" = Adjustable Ride Height?
