Big Bend Rear Bumper Removal
Tdub0527
Ted
Minneapolis
'21 Bronco Badlands, 2024 Rivian R1S
I'm going to remove my bumper tomorrow to install the Ford trailer hitch. I found a video from AIG on youtube and it looks pretty straight forward. However in the video the bumper they have doesn't have sensors. I have the Big Bend with the rear plastic bumper and it has sensors. I haven't had a chance to peak under there so I thought I'd ask if anyone has had trouble removing this bumper or if it is straight forward with another plug to unplug.
Any advice is appreciated.
Here is that youtube
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
If it's the same as my front mod bumper, all the sensors are tied into one wire bundle that has a harness you can unplug. Just unplug before taking off the bumper.
Hopefully yours is just as easy.
dan79
dan
ma
08 f250
I put on the rc hitch, they want u to remove the bumper but I didn't feel like doing that if I didn't need to so I put the bolts in from the front to the back and there was no issues took me all of 5 minutes to do
Tdub0527
Tdub0527
Ted
Minneapolis
Just finished up installing Ford hitch. The bumper with sensors had one additional wiring clip on the passenger side for the rear sensors. Otherwise this was exactly like the video.
Two easy wiring clips to unclip and 8 bolts. Crazy easy!
Skanderbeg
Everglades
Rav4
Everglades
I installed the hitch, but I'm having an issue with the connectors I'm not hearing a click when I connect them. It's giving me a parking sensor fault error. Did you have any issues connecting the connectors back?
Tdub0527
Tdub0527
Ted
Minneapolis
It’s been a while but I remember it clipping in pretty easily. We’re you able to resolve your issue?
Skanderbeg
Everglades
Rav4
Everglades
Not yet I’m gonna try it again Sunday. I’m going to use some silicone spray see if that helps.
Bronco_Mo
St. Peters, Mo
2023 Outer Banks
yes I'm having an issue reconnecting the sensor connectors and I too am getting parking sensor fault...
kpecks
Kenny
White 2023 Wildtrak 4dr Lux
Same here. Installed hitch. One connector “clicked” back in, the other didn’t. Not sure why but I have the fault now too.
BBSas
Alabama
Installed the drawtite hitch without removing the bumper as well..
popo_patty
Caleb
Sacramento
I replaced my rear and I too had an issue reconnecting my parking brake sensors. In fact, it was so hard to replace them I broke them trying to get them to clip back in:(.
PrepVet
North Central WI
A bunch.
I'm putting mine on this week/weekend. This video was helpfully to make sure I got everything unhooked and didn't just pull.
I don't recall if I saw the instructions in the box now, what was the tq spec for the bolts? Eh, I'll just uga-dugga them in really good.
mikkibtune
Mikki
saratoga springs, ny
Ford Expedition King Ranch, Ford Bronco
NEW HITCH and the parking sensor party.
So I self installed a new hitch for an upcoming trip. I squeezed the clips on the sensor harness but they were still kind of hard to release . I did the usual wiggle and they finally gave. Now I went to put them back in and NO BUENO. No click, and it threw the parking sensors every time I started the vehicle. Apparently not EVERY Bronco has these issues but some do.
The problem: Let's face it, you're upside down, the clips are in a hand cramp spot behind those fender well cut your palms up plastic liners and you can't even SEE everything you need to, because theres two different sets of male pins on each plug that go in differently and ya don't want to bend those by forcing them. . Besides, theres just enough play there the way its mounted to kind of send things in a bad direction if you push too hard.
1. I removed the harness from the mount and pulled it gently over the top of the bumper where i could SEE EVERYTHING in the light .
2. I checked for dirt, debris, bent pins, malformed gaskets, plastic housing or other f-ery.
3. I blew some compressed air in there anyway just to be sure because SOMETHING was causing that clip not to go over the catch. That didnt do it.
4. The plastic housing was slightly mis-shapenso I squeezed that a little but that didnt do it .
5. No pins were bent and thngs lined up the way they should.
6. I sprayed some pam cooking spray not only on the insides of the housing but the outsides of the male end of the plug.
7. I visually aligned things perfectly but also started kind of at a slight angle to make sure the pins actually entered the holes properly first, and slowly.
8. I pressed on the tabs to release the catch inward as much as possible and STILL had to press really firmly to get that plug to catch.
Outcome: My problem is solved . My alarms are no longer sounding and all seems functional and well. I do have some concerns about this plug breaking for people.
Side Note : a CRAP TON of dirt / road debris collects in that section of the vehicle too. Im tempted to really wrap that connection with a ton of electrical tape and then pound the p*ss out of that whole area with undercoating because I live in the salt belt .
RedDawg
Erik
PHX AZ
After reading this thread about issues reconnecting the wires, and struggling to disconnect my one clip, I decided to try and install the Ford tow receiver with wiring intact.
Successful, and easy.
FYI the wire looks taunt, but it has plenty of play in it.
Ford Bronco Big Bend Rear Bumper Removal IMG_9642
