Best Practice 5 Tire Rotation?
Bschurr
NY
I would guess that +90% of Jeep owners don’t do a 5 wheel rotation.
<dons flame suit>
I pay $99 for 3 lube, oil & filter changes including a tire rotation at my local Jeep dealership so for $33 I don’t have to deal
JaxGtc
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Mark the base of valve stem of the spare with some finger nail paint/polish.
JaxGtc
Deleted member 19970
Guest
I doubt there is any kid in a garage that will just switch the caps and tell you it was done...
Haha, no doubt. They lose them half the time anyway. If ya want something done right...
Pancho Kornwallace
Pancho
Mustang
Incorrect.
1. You are wasting a tire that way
2. You will have replace your set of tires 20% quicker if you do that.
3. If you do need to use the spare, it will not be worn down correctly and make your ride more uncomfortable.
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
<dons flame suit>
Yup cause it’s pointless to rotate the 5th tire, if the point is even tread wear...it will not be even tread due to driving patterns. Unless you are driving same location, stopping at same places, same time every time every day...there will still be inconsistencies...even your with your fist rotation, the other 4 will already have different tread wear than your spare...
Gamecock
<dons flame suit>
Why wouldn’t they? That’s crazy...I guess unless you have a tire cover (stuck in the ‘80s), but if the Jeep is built with big tires or 33+ in general those are rare. Everyone I know that cares about their Jeep and is a “Jeep person” rotates 5. Most places don’t charge extra to rotate in the 5th. Just give them the rearward cross diagram when you drop it off....and always rotate all 5. Otherwise when you change tires or you have to buy the same exact tires, or you’ve wasted 20% of your tire life.
mtap
Mervin
Cape Coral, FL
Incorrect.
3. If you do need to use the spare, it will not be worn down correctly and make you ride more uncomfortable.
incorrect perception...your spare is only supposed to get you home or somewhere to get broken tire fixed. That’s why donuts are smaller on other cars...let’s say the messed up tire cannot be fixed and you end up getting a new tire for it, now that tire is not the same as the rest.
Gamecock
Why is it pointless? Your tires go 20% further before you have to change tires. It’s ignorant not to rotate 5, as again...then you’re stuck with the exact same tire or you wasted the treadwear (or you have to use a stupid looking cover).
mtap
Mervin
Cape Coral, FL
so when it’s time to replace tires, now you have to replace 5 instead of just 4 since you put the spare in rotation...
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
Gamecock
True, but you went 20% further so the exact same total cost but you went longer without new tires...and you’re not stuck with an oddball tire if you decide to change sizes or tire type.
