Baseball caps - where are you putting them?
22Badskwatch
Sacramento, CA
2022 Badlands Sasquatch
Patriotic
Patriotic
Peter
'22 Bronco Wildtrak; ‘25 Porsche Carrera Cab; ‘20 BMW X5
^^Great idea.
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
Frequently phone charging area behind the gear shift.
KABQ
Aaron
Albuquerque, NM
What sticks out of a man's pajamas that he can hang his hat on?
His head, obviously. Y'all are gross.
stickshifthappy
RVA
Ford Ranger, 65 Mustang
Hasn't happened yet, guess I've been lucky.
We had a casualty 2 weeks ago. windows down, top off, and whooosh, it was sucked right out.
Topless vehicles with the aerodynamics of a brick tend to have interior tornadoes pop up from time to time I've found.
gaaangs
Ohio
Jeep
I recently built my own custom "hat holder" mod on my Bronco.
I 3D printed a hook that attaches onto the passenger side of the vehicle. When I press a button the hook extends to the driver side, reaches up, and takes my hat off my head. It then retracts and holds the hat until I need it again.
Actually, I just toss my hat on the passenger seat. Don't overthink it, man.
greatlakes
Grand Rapids
67 Buick Special
I keep an "emergency cap" in the rear storage pocket where the sub would be on the B&O system. That way I always have one if I choose to drop the top spontaneously.
BlueBronco
DFW
Had posted this in the best mods thread. Patent pending.
I needed a solution after having a hat almost slide off the dash when I was cruising doors off. Is it pretty, nope. Does it function as intended, yup.
Ford Bronco Baseball caps - where are you putting them? 1683730660214
Ford Bronco Baseball caps - where are you putting them? 1683730667883
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
The whole point of a cap is being able to wear it inside the Brinco. The true struggle is wearing an actual brimmed hat in a modern vehicle. Pickups lend themselves to the wire pull down rack, but I see no option for a hat rack in a Bronco.
Blksn955.o
Greg
Wentzville, MO
17 Ford Escape Ti, 94 Ford Mustang GT, 21 BL
on the passenger left grab handle is where i put it.
Yep, I do the same. No issues yet as I put it with the bill of the hat sitting between the seat and center console...ie think of the grab handle wearing it backwards.
AZMikeL
AZ
Does that mess with your instrument cluster and screen? Whenever I shove my hat up there, the whole thing goes into night mode because that sensor up front thinks it's dark out.
Like others, I just find a place to shove the hat, but mostly wear it with the top down due to being folicly challenged up top!
BlazinGrizz
SC
2023 Ford Bronco OBX / 2020 Subaru Ascent Touring
I use my knee usually, but also have these hooks from Amazon in all of our vehicles. I love them, although it may not be what you’re after, they clip onto the headrest post and you can easily flip them which ever way you want. 👍🏼
Ford Bronco Baseball caps - where are you putting them? 085D380F-6940-4010-B496-BEF5F0F32B86
