Base Bronco fog lights wiring question
SGXIX
How should I modify the attached aftermarket fog lights wiring in order to connect it to aux switch? The harness comes with 3 pins/cables, while aux switch only has 1 cable.
Ford Bronco Base Bronco fog lights wiring question Screenshot_20230715_214642_Amazon Shopping
Ford Bronco Base Bronco fog lights wiring question Screenshot_20230715_223338_Amazon Shoppin
RagnarKon
Ford Bronco, Escape, Focus
The switch will have the following:
  • Power to the switch
  • Power from the switch to the relay
  • Ground
The power wire that runs from the switch to the relay needs to be replaced by the Aux switch wire. The other two aren't necessary.
The relay is the black box in the wiring harness. Should have four (or potentially five) wires running to it.
  • Power from the battery
  • Power to the lights
  • Ground
  • Power line from the Aux switch that triggers the relay
Ford Bronco Base Bronco fog lights wiring question 1689478678809
Option B is to cut the entire relay/fuse/etc. out and power the lights from the Aux switch itself. Should be fine, just know what the amp draw is and pick the correct Aux line.
Ducati1098
You only need 2 wires. Power comes from the Aux switch wire , the other to ground. No need for that switch or relay pictured.
SGXIX
Cutting it and connecting directly to aux switch seems to be the easiest option. The lights are rated 40A. Thanks guys!
Ducati1098
The highest aux switch rating is only 30A, so if that number is correct you may need to wire in that relay. Seems crazy that those 2 little lights are 40A
SGXIX
"30A fuse & 40A relay" is what product description says. I'm not sure if it is 30A or 40A at this point lol
Ducati1098
Do you have a link for the lights so I can look at the specs?
SGXIX
Lumimotor Flush Mount LED Pods w/Wiring Harness 2pcs 50W CREE LED Backup Lights Flush LED Light Bar Work Light Fog Lights Auxilary Bumper Lights for Truck Pickup UTV ATV SUV Trailer 4x4 Car https://a.co/d/bVVLb1r
Ducati1098
Okay nevermind. 50 watt is nothing. You should be fine using any aux switch you want without needing the additional relay.
