Base Bronco Fog Light Wiring Question
Little Foot
Buffalo
non-SAS Badlands
I have a Base that is coming in and want to upgrade the front bumper to a Big Bend that has the fog lights. I have no interest in cutting off the hoops or anything like that, so the Big Bend or higher plastic bumper will work just fine.
When reading other threads, can anyone confirm if the wiring is installed for the base? I know that I will have to install the different light switch and then activate the system/fog lights. I just want to confirm the wiring harness so that I know everything "should" be plug and play so to speak.
If anyone has already done this mod, please reach out with a link as I was not able to find it thru our search engine.
Thank you
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Do yourself a favor, and get an HD Modular bumper if you are swapping out bumpers. You'll have a lot more options then you would with the plastic bumper.
Chances are, wiring is there but you'd just need to buy a factory fog switch. The HD Modulars have a pigtail there (which is a DIFFERENT pigtail then the plastic bumpers oddly). So I don't see why a base wouldn't have SOME kind of pigtail there to utilize if you program the feature on with FORSCAN.
But again, get an HD Modular.
Little Foot
Little Foot
Buffalo
non-SAS Badlands
Unfortunately, my build that has been picked up is coming with the plastic bumper.
