Fog Light wiring with no fog light button
Jeremy
TN
2022 Bronco
If you have the wiring for the front parking sensors (High/Lux package) all you need to do is buy the switch panel that has the fog light switch built into the headlight control panel, and then do some minor Forscan tweaks.
Part No.: M2DZ-11654-xx
The "xx" at the end will vary based on your specific package... if you post your equipment package and model year I can get you the exact part number you need.
If you didn't want to go with that route, it is honestly probably easier just to run new wires to the bumper or use the pre-run aux wiring that runs up to the grille. The wiring harness for the bumper runs just behind the fender on the driver side, but after that it quickly get bundled up in a beefy wiring harness you probably don't want to cut into. (But if you do I can get you diagrams and pinouts once I get home.)
I have a 2022 Black Diamond equipment group 321A. Could yiu share the part number I would need.
JDinNC
SOBX
'24 Wildtrak, '18 GLC300, '16 S1000XR
24 Wildtrak Lux here.
interested in the Ford fog switch to run SAE fogs and then tie two driving lights per pod to an upfitter switch.
