BAMF Tailgate reinforcement
Status
Not open for further replies.
BAMF
BAMF
Jerry
Benicia CA
www.bayareametalfab.com
Two 2021 Broncos
Brandon Miller
Pollock Pines, CA
2022 Badlands
I just tapped the tailgate and threaded the bumpers in with the bolts provided. Done, spare back on. Now I need to figure out how to limit the tailgate travel so I can mount a double water/fuel holder next to the tire (rotopax mount with extension to mount two 1 gallons for water/fuel). This seems like a very simple bracket for you to sell, and not exactly difficult to fabricate as well.
Ford Bronco BAMF Tailgate reinforcement PXL_20221219_203739111
mvilla
San Francisco
4-door Badlands Bronco w/ Sasquatch package
Does anyone know if this would work with the DV8 rear license plate relocation bracket?
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Works, look at Stinky fab racing they have a better designed bracket that doesn't rub the paint.
isaacfinnegan
Isaac
Hawaii
Finished product (MFC carrier is almost finished):
How is the lower part mounted? The hinges pictured above in post #166 look similar to stock hinges and don't have additional tapped holes to bolt into.
Asking, as I have the hammerbilt mounting for raptor hinges, but the hinges I got are like the ones in post #`166. Not sure how to mount this thing.
Mine pictured here:
Ford Bronco BAMF Tailgate reinforcement PXL_20240317_005441431.MP
broncorik
Mine pictured here:
That lower hinge is not a Raptor hinge...the Raptor hinge has the same configuration as the upper hinge shown in your picture (different part number, however).
The older HB plate was drilled with wider holes to fit the OEM hinge, and I believe the newer version has holes that will fit either the OEM hinges (by using RTR spacers or HB delrin tapered spacers), OR using the more closely spaced threaded holes on the Raptor hinges. How did you get mismatched hinges? I have a spare set of OEM hinges in carbon gray if anyone wants them, but if you want to use your setup you need another (lower) Raptor hinge (or go with an OEM upper and use spacers...but that IMHO would defeat the purpose of using the stronger Raptor hinges).
NoloBronco
Nolensville Tn
2022 Bronco Badlands SAS
Any pics with the tire mounted?
Desert_6G
Phoenix, AZ
Ranger
is a tailgate reinforcement necessary if I'm going from a non sas wheel and tire to wheel and tire that weights slighly less than the sas?
Blaylock1988
Colorado Springs
2021 Ford Bronco, 2004 Volkswagen R32
Anyone run this reinforcement with 37s on factory Sasquatch wheels?
Status
