Ball clearance question
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
I have non-SAS Badlands with factory receiver hitch - bought a ball/receiver today and stuck it in and noticed how little clearance there is with my 33" KO2s. I'm upgrading to 35s. Is this a problem?
Ford Bronco Ball clearance question 1709762506678
Ford Bronco Ball clearance question IMG_0549
Roger123
Roger
VA Beach, VA
darinhouston
Darin
U.S.
Thanks - maybe I should just take it back and get a longer one then. I just bought it.
RagnarKon
Ford Bronco, Escape, Focus
If you know what you're towing, you should also make sure you don't need a drop hitch before you buy something.
My drop hitch provides enough extension on its own that I don't need to specifically buy an extension.
Ford Bronco Ball clearance question 1709763730319
darinhouston
Darin
U.S.
I would guess that most small utility trailers would be low enough to need a drop hitch, especially if I get 35s. (Badlands)
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
im in a sasquatch and a 5.25" drop makes me pretty level with a haulmark trailer
RagnarKon
Yeah you'll need something.
I have a non-Sasquatch Badlands with 33s and needed a 4.5" drop hitch.
Pilsner
JTR, 81 Bronco, 21 BD
This is the answer. You likely want a drop hitch anyway to tow close to flat, but that depends on your trailer. I use a drop hitch on mine.
ChrisB351
Shreveport, LA
You need a drop receiver. I have a 3" on mine. My gate and spare will clear my 2 trailers howevery. I open it then connect my trailer. The tire clears just enough the latch wont release so its also theft prevention.
If you can fit the hitch in there then it’s fine. You can take the spare off to fit it and set it back on if you want (or just throw the spare in the trailer)
But otherwise yeah - drop hitch. Do not go with an extension. 3” drop barely cleared being able to latch the hitch lock without having to take the off spare with 35”s on the OEM spare carrier for me.
Dan-O
Dan
Fountain Hills, AZ
Just keep in mind that any drop or extension is going to change the towing/tongue weight numbers, more drop or extension is going to reduce capable weights. Just keep that in mind…..
Tdub0527
Ted
Minneapolis
'21 Bronco Badlands, 2024 Rivian R1S
A drop hitch also reduces tongue weight? I knew about extensions but not drops.
