- First Name
- Adam
- Joined
- Aug 30, 2021
- Threads
- 555
- Messages
- 6,159
- Reaction score
- 7,050
- Location
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- Vehicle(s)
- 2018 Raptor & 2021 Bronco Outer Banks
- Your Bronco Model
- Outer Banks
We have a few LP9 Racer in stock and a bunch of LP9 Sport in stock for those interested.
The way you'll want to mount them to your hoops is with something like this:
https://www.amazon.com/Nilight-9002...1_2?keywords=tube+mount&qid=1639840275&sr=8-2
There are other kits on amazon like this. But they go around the tube and then give you a mounting point for your light.
LP9 Lights: https://www.4x4truckleds.com/led-auxiliary-lights/baja-designs/lp9/
And 2 ways to wire them up. The easiest, if you have the factory upfitter switches, is get one of these (per light): https://www.4x4truckleds.com/baja-designs-lp-series-controller-module-harness/
It just plugs into the light and gives you 4 wires on the back you can tie into the upfitters. Another option is this harness, which will power TWO lights and provides a relay with it and a switch:
https://www.4x4truckleds.com/baja-designs-lp9-harness-2-light-max-pro/
