Baja LP9's on a HD modular bumper?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We have a few LP9 Racer in stock and a bunch of LP9 Sport in stock for those interested.
The way you'll want to mount them to your hoops is with something like this:
https://www.amazon.com/Nilight-9002...1_2?keywords=tube+mount&qid=1639840275&sr=8-2
Ford Bronco Baja LP9's on a HD modular bumper? 1639840286298
There are other kits on amazon like this. But they go around the tube and then give you a mounting point for your light.
LP9 Lights: https://www.4x4truckleds.com/led-auxiliary-lights/baja-designs/lp9/
And 2 ways to wire them up. The easiest, if you have the factory upfitter switches, is get one of these (per light): https://www.4x4truckleds.com/baja-designs-lp-series-controller-module-harness/
It just plugs into the light and gives you 4 wires on the back you can tie into the upfitters. Another option is this harness, which will power TWO lights and provides a relay with it and a switch:
https://www.4x4truckleds.com/baja-designs-lp9-harness-2-light-max-pro/
Broncorich
Rich
Sarasota
the lp9 s fit like a glove. 6 holes drilled into the bumper no bracket overhang. The lights are mostly protected by the brush bar. You are more likely to break a headlight than the lp9 which are hardened plexiglass and are serviceable. Just get someone that knows what they are doing and don’t listen to internet BS
Ford Bronco Baja LP9's on a HD modular bumper? ACF1B62E-04FA-4BE6-8317-8142F36235BE
Ford Bronco Baja LP9's on a HD modular bumper? A956C0D7-4F44-494F-A636-DE91C2093AC8
Ford Bronco Baja LP9's on a HD modular bumper? 12F63018-8008-463E-9A53-4112BD7137FE
Raptor911
Raptor911
Broadlands, VA
I have a pair of LP6s ready when my Wildtrak arrives. If you don't want to drill your mod bumper than you can use this bracket >> https://gglights.com/products/2021-...52030&pr_ref_pid=6914069954718&pr_seq=uniform.
The single mount (see below). The 2 smaller holes are for the factory bronco bolts. The pill like hole is for your light. I will drill this mount for 2 holes on either side to accommodate the LP mount
Ford Bronco Baja LP9's on a HD modular bumper? 1643130851785
doccoch
doccoch
Doug
Midland, Texas
2019 Mustang Bullitt, 1967 Mustang Fastback
that would be good but like I (the OP) and Broncorich above have a bull bar and push bar and have take up those spots. Therefore, drilling is only option if we want sitting ON the bumper.
Raptor911
Raptor911
Broadlands, VA
You are correct. It would not work with the bull bar
doccoch
doccoch
Doug
Midland, Texas
that looks really really nice. With my push bar, which extends at a more forward angle, the lights would sit a bit behind the most anterior point. It also looks like 3 would fit if one wants to squeeze it in.
So, when considering drilling into the bumper. Can you comment? Obviously, we are no longer dealing with a threaded pre-placed area for a "bronco bolt." It's not plug-and-play. Do I have to remove the bumper, drill a hole, and then place a nut behind the hole to hold a bolt in place?
Broncorich
Rich
Sarasota
The bumper doesn’t have to be removed. Drilling was relatively simple. You can get them from the front underneath with a small wrench. The wiring harness plug goes right through the grill without modification. If you put a third light in it with block adaptive cruise control as well as the front camera. The Lp9 pro lights are very bright and provide plenty of light.
doccoch
doccoch
Doug
Midland, Texas
I can see how it would block the camera, but how would it block the ACC plate sitting underneath it?
Broncorich
Rich
Sarasota
I am not an expert on this topic. So my advice is worth what you are paying me. The adaptive cruise is not a focused beam. So it might be affected. Mine is not but I was concerned until I tried it. My 360 camera facing forward is slightly compromised by both lights on the side. It’s not a big deal to me
doccoch
doccoch
Doug
Midland, Texas
Ok, thanks for help.
Anything sitting ABOVE the bumper will not affect the adaptive cruise control. My understanding is that Ford and most car manufacturers employ simple laser tech while a few Japanese companies are using optical systems based on stereoscopic cameras. The front view camera interference is a different story and what you can live with.
Broncorich
Rich
Sarasota
it sounds like you know much more about than I do. So it shouldn’t be a problem then. You will be very happy with the LP9s. It was really simple (45 min) and I am not DIY guy.
We_Love_Tacos
www.bronco6g.com
2021 Ford Bronco First Edition 2Dr Lightning Blue
When you have time, please post some pics of your lights and mounts up close from all angles. I’d like to see more of the detail.
Thank you!
doccoch
doccoch
Doug
Midland, Texas
Thank you!
I'm so torn between doing this and 4 of their XL lights. I really really like the look of what you've done here.
jcgcbns22
Caleb
Nova Scotia, Canada
That looks perfect. I am going to try the same with my 8.5 inch Teralume (pair) if I can fit them under my 9 inch Greenlane bill bar. Mounting above the bar may be possible too, but I think more effective mounted on the bumper itself. Thanks for the pics
