Baja LP9's on a HD modular bumper?
We_Love_Tacos
www.bronco6g.com
2021 Ford Bronco First Edition 2Dr Lightning Blue
Can you post a pic of how much it blocks the 360/front views?
You can literally scroll up and see pics.
TTT
Alberto
Baja
Mustang Mach E Premium
Got my two LP6s installed using the outer two mounting points on the Swarfworks bracket. Amber backlighting tied to DRLs, Aux 1 is low beam, Aux 2 is high beam.
can you show us how the camera looks with the lp6? does to covert to much visibility??
NoloBronco
Nolensville Tn
2022 Bronco Badlands SAS
Can not decide between amber and white. What made you go with Amber for your LP6’s?
NoloBronco
Nolensville Tn
Two reasons: I like the contrasting color aesthetically, and the amber light improves viz in foggy or dusty conditions.
Do you care to grab some more images of the set up in different lighting conditions?
iSurvive
Robert
Denver
2023 Ford Bronco Raptor
The bumper doesn’t have to be removed. Drilling was relatively simple. You can get them from the front underneath with a small wrench. The wiring harness plug goes right through the grill without modification. If you put a third light in it with block adaptive cruise control as well as the front camera. The Lp9 pro lights are very bright and provide plenty of light.
I can see it blocking the front camera, but isn’t the ACC module dead center in the lower part of the bumper? That’s where it sits on most Ford trucks.
iSurvive
Robert
Denver
That looks like the LP series would bounce around a lot unless they are bolted TO the bumper. I only see a single mounting point on each side and a long piece of metal. That would flex in the middle and bounce around.
The SwarfWorks one has a bend in it so it bends upwards and allows clearance for the bolts. It also means it's not going to FLEX on you since it's bent upwards
https://www.4x4truckleds.com/swarfworks-triple-lp6-light-mount-for-2021-ford-bronco/
This is the kind of info I love hearing from a vendor! The first thing I thought about was weight of the lights, real off-road conditions, and flex. Adding bends/folds in metal adds tremendous rigidity.
The molle panels in my last truck bed were made by Valhalla Off Road. They folded the metal about 45 degrees on all sides of the panels. In my opinion they put every vendor to shame. A little extra attention to detail was a game changer!
iSurvive
Robert
Denver
It looks and is no different than aux2 only. BD says not to do this, though, because it unnecessarily runs extra power/heat into the assembly. These lights are amazing — hard to believe some are running as many as 6 of them. Low beam is more illuminating than the OEMs on high.
Rigid Industries engineer also told me not to turn on both Upfitter switches for the Rigid Adapt Series lights. That’s why they come with a 3-way switch. Someone told me it was ok, but the other person said “highly don’t recommend”.
Red Five RN
Jeffrey
Oklahoma
Ford Bronco Wildtrak
I wonder if you would have enough room to mount a 6 inch light bar between in a spot?
Darcyjs14
D’Arcy
Seattle
1970 Ford F250 Camper Special 4spd
I run 4x LP6 on the bumper. Controlled via SwitchPros panel, with a total of four circuits being used (2 spots, center, as a pair, with one circuit as high, the other as low. 2 wide/cornering, same configuration as the spots)
you could get LP9s on this mount but they would be partially obstructed by the top of the bar. That said, the fabricator who made this Nerf bar (i know it’s different from what Jeepers call a nerf bar but that’s its actual product name, so we don’t need to debate whether calling it a nerf bar is accurate or not) would undoubtedly make a variant of it for the LP9s if the buyer was willing to pay a bit extra. US made in Kansas by Allied OffRoad (@AlliedOffroad). Been on my truck for two years, regularly used in all kinds of conditions and has held up beautifully. I paid retail for mine, so not shilling for them, other than as a happy customer.
in the middle of my bar up against the bumper is the camera relo bracket, so I lose none of the baja forward visibility with this setup. I had one of the first of these bars and I think he’s improved the way the camera relo works in later releases
Ford Bronco Baja LP9's on a HD modular bumper? IMG_7141
