B&O front speakers worth changing?
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
Any update with the 300hz blockers?
Yes they sound good but I need an additional wiring harness to hear them both with the 300 htz and without any blocker to determine if there is a significant difference. Tested the Kicker with the 300hz again and hertz sounded a little better.
I should get a few more wiring harnesses Fri.
I don’t think it will be worth ripping out the 4” kicker CS in the rear without upgrading to 6.5s.
talbot
Calgary
2dr BL AMB
Did you get your 6.5s?
i have them but havent installed yet to try
be doing that this weekend, and i’ll test blockers on the front 4” as well
interested in your blocker optimal blocker findings
Mason09
Mason
Orange county
23 4dr Bronco Badlands/22 Expedition Stealth
I‘m curious to see both of your set ups as I plan to do the same. Keep us posted!
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
I’m waiting for the test too, before buttoning everything back up and driving it again.
The 4” kicker CS that I’m not using will go into coworkers bronco. Need to see if the same blockers tested good with them in my rig will sound the same in his without B&O.
Next thing I might do later is update the pods for 6.5s add Kicker KS. I’m not going to touch the kick panel again, unless I plan to update the amp.
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
Results are in:
Get the 300hz bass blockers! Tested with and without installed at the same time. Without blockers, louder, more treble/sharp actually, and clearer. The treble and sharpness without any blocker is too much imo, and cannot be equalized.
With blockers, more bass, more dynamic fuller sound, but quieter. It was quite evident listening to All Right Now classic rock song by Fire and Water. Yep. I only have one blocker so, waiting on another order.
I’m still shocked there is more bass with the 300hz bass blocker. 🤔
Odd, my rear audio in the back keeps cutting off after 20 mins.
Ford Bronco B&O front speakers worth changing? 5A435D6E-0BD7-43BA-8F6F-3CBFF84BD0E5
Skar Audio SK300HZBB-PR Elite Frequency Filters - Eliminates Frequencies 0-300 Hz at 4 Ohms - Pair https://a.co/d/8C79gjh
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
Current setup, which I’m fine with for now.
B&O OEM Amp, Sub, kick panel.
Front: HERTZ Dieci Series DCX-1003 $130 w/ 300hz Bass Blockers
Center: PRV AUDIO 4 Inch Midrange Speaker 4MR60-4 $24
Rears: 4” Kicker CS. $62 correction, replacing with Hertz 4”
I think it might be worth getting the Hertz for the rear if they are louder. But, since I already have the kickers, I’m just going to leave them. It’s more of a sound fill.
bradcd
Brad
Saab 9-3
I really appreciate you documenting each step of the way with incremental results. I've been following along and would probably replicate your setup. I wish to do simple speaker swaps only. Thank you for your trials!
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
If I didn’t have so many Kicker CS, I would get the Hertz or Kicker KS for the rears. I’m sure upgrading to 6.5 Pods would be the most effective, but I’m not going down that road and dropping another $300. The hetz 4” without blockers, might be loud and clear enough to heat back there.
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
Eq set to Stereo. Treble and bass 3 clicks from max. Midrange 3 clicks from center. A audio guy told me that, sounds good.
bradcd
Brad
Saab 9-3
Wouldn't 6.5" in the rears require more power to drive resulting in lowered volume over the 4"?
Also try negatives in an EQ, everything in reference to zero as your max. You can't amplify a signal without degrading it. So keep your treble and bass at 0 level, then set your mid to the appropriate negative. It may sound better.
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
Yeah that’s what I’ve been wondering, but there are people here that added them without upgrading. Mostly people without B&O that can FORscan more power to the rears. That said, without doing anything, a bigger speaker should move more air and more sound right? Simple physics, which I failed 😞
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
Just tested the Kicker CS and Hertz against each other (no blockers) in fronts. Hertz wins in clarity and overall sound. They are a bit louder too.
Yes, it’s worth getting hertz for the 4 speakers. Even with just swapping w/ 4”.
Buying more Hertz I guess uhh. No blockers on the rears.
The balance of sound should be perfect with the loudness & clarity of Hertz without blockers in the rear and with blockers in the fronts.
Ford Bronco B&O front speakers worth changing? 3B58E883-3859-4351-B092-F8D5B5F1212C
HERTZ Dieci Series DCX-1003 4" Two-Way Coaxial Speakers - Pair https://a.co/d/8fyvOUM
talbot
Calgary
2dr BL AMB
I just did a quick swap of the Hertz DCX 165.3 in the passenger kick panel and I think it's an improvement
everything is subjective, but to me better clarity, range and much better mids and high's
slighly less overall volume and not as heavy on the low's as the b&o
thanks for the feedback on the blockers @WheresMyCar
on the weekend I'll swap out the driver kick panel and try blockers on the front's
