B&M Sportshifter (cont)
Uila6g
Hiwa
Hawaii
2023 Manual Bronco
I just installed my B&M Sport shifter yesterday. Has anyone else experienced it being kinda stiff compared to the stock? Also, when I shift to second and fourth its like a click and I’m in already. Anyone else related?
TLO
Canada
youtube.com
2 door
Have you ever tried a weighted shift knob. First mod I make to any standard.
TWM makes some nice ones... Dunno if they do a Bronco. But it makes shift feel so much nicer
CalvinT
Calvin
Phoenix, AZ
I'd expect it to be a bit stiff compared to stock. Shorter throw means less leverage which means more effort. Archimedes can tell you all about it.
Aut-Lin
Aut-Lin
Sun Peaks, CA
2021 4dr Black Diamond
Sounds like mine, working as intended!
It's definitely more of a notchy feel when going through the gears, almost like a gated shifter feeling. The stiffness will loosen up a bit as you use it more.
Uila6g
Uila6g
Hiwa
Hawaii
2023 Manual Bronco
I have not but maybe later I’ll look into a heavier knob after i get used to the feeling of this
  • Like
Reactions: TLO
Uila6g
Uila6g
Hiwa
Hawaii
2023 Manual Bronco
Gated is exactly the term. The stock was like a ways into first and then a notch and second but with this stick theres no notch i pull back and im already in
Michigander
SE Michigan
SuperDuty
Did you perform the last step to adjust the shifter cables?
Mine had a feel similar to what you described even after adjusting the cables. I adjusted them again and it's fine now.
Be careful with those orange clips. They break easily (ask me how I know).
Also, the shifting got stiff on mine after a few thousand miles. I sprayed some Boeshield T9 on the pivot points and it's nice and smooth now.
irishmurph01
Pat
26’ bronco heritage
Has anyone installed this on a 25’ yet? Holley’s website says figment only good up to 24’. But they haven’t changed anything in the stock shifter since then right?
