ARB Air Coupling, Antenna location
nottinbe
St. Louis, MO
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Finally got around to installing my ARB dual compressor and bracket by @4x4TruckLEDs.com. I was inspired by @das solution as seen here, and thought I'd post my results and parts list for anyone interested.
1 x ARB Air Hose Coupler (JIC version - NOT the one that comes with the pump up kit)
1 x ARB 90 JIC(m) to NPT(m) (for insertion into the compressor)
2 x ARB 90 Elbow JIC(m) to JIC(f)
1 x ARB 45 Elbow JIC(m) to JIC(f)
1 x ARB Reinforced Hose JIC, 1meter
Is there a reason you used to many fittings and didn't just go right into the back of the coupler with the hose???
nottinbe
nottinbe
St. Louis, MO
Yes, the location I choose in the windshield cowl is above whatever that black piece\tray is below it (can be seen in the pic of the hole drilled). The first couple inches of the hose have no bend, so it was not possible to fit the hose directly into the back of the coupler. I started out trying just a 45, but that didn't give the right clearance. I made a few attempts, and was trying to minimize fittings, but the best fit without any rubbing or pressure was the two 90's and a 45.
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
very cool I like that, nice install
mdk100
Los Angeles
Porsche 911, Cayenne, BMW X3e, 2 door BaseSquatch
So is the coupling attached to the cowl with a threaded nut? Doesn’t the rubber on the coupling need to push back to release an attached hose? I’m trying to sort how to do the same. Thanks
nottinbe
nottinbe
St. Louis, MO
Yes that ARB coupling comes with a threaded nut.
Yeah you need to push down the rubber coupling to release it, but it sits in its normally-released position. When you insert the air hose it pops up. Then you push it back to that resting position it releases.
mdk100
Los Angeles
Great thanks! I’m going to try this.
@4x4TruckLEDs I’ll be placing an order for the parts. I’m behind the curve now for my spring break trip. Just fyi it would be nice to update your website to make the adapter required for the single compressor more clear. I was wondering where the air output was!
mdk100
Los Angeles
Got everything installed and tested out off-road last week! Ingenious air chuck location! I can top off tires without opening the hood. I dropped to 20 lbs off-road, and got back up to pressure using an ARB single for just a few minutes per tire. I did lift the hood for that. All in all, great mod and nice package from @4x4truckled. Another thread on the single ARB was also very helpful.
Ford Bronco ARB Air Coupling, Antenna location IMG_0045
Ford Bronco ARB Air Coupling, Antenna location IMG_0042
Ford Bronco ARB Air Coupling, Antenna location IMG_2317
Gluestick
Josh
Nashville
instagram.com
I really like this since I would have to open hood which requires limb riser removal. I may change my layout.
tcovington
Tom
San Francisco
'16 Ford Focus RS, '25 BadSquatch
1 x ARB Dust Cap
Thanks for the inspiration (and the parts list). My install here.
Ford Bronco ARB Air Coupling, Antenna location IMG_1079 (1)
Gluestick
Josh
Nashville
instagram.com
Nice! I was similarly inspired and did the same using Apex panel mount:
Ford Bronco ARB Air Coupling, Antenna location IMG_5037
tcovington
Tom
San Francisco
The Apex stuff is pretty. I'd already committed to a Morrflate system, but I kinda wish I'd found Apex first.
