Applying Thread Tape to Dash Accessory Mounting Point?
rcl4668
Pacific NW
2019 Mustang Bullitt, 2023 Bronco Heritage Edition
Thanks to another poster, I assembled a phone/GoPro magsafe mount that attaches to the upper dash accessory mounting point. Works great except that over time because of the eight when the phone is attached, he base mounting point becomes loose and the whole assembly sways, sometimes tossing the phone in corners. I have tried tightening repeatedly but it always comesloose over time. Any issues with using white thread tape over the screw that goes into the dash? I assume that the tape won't become fouled in the accessory point if I wantot remove the phone mount later. hanks!
dgorsett
colorado
F250, Mustang, Explorer
Idk if it will work in your case, but thanks for putting this in my mind. I'm always looking for a thread "snugger" but never thought of using T tape in a non sealant application!
I don’t know that will accomplish what you are looking for, but if it works who am I to argue
My first though would be see if there is enough thread to get a locking nut up on top, then when you install it you back the locking nut out to snug it up.
If that won’t work I’d get some 222 loctite
Roger123
Roger
VA Beach, VA
A dab of Blue Lock-Tight
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I second this - You can still remove the bolt easily with hand tools, however it should prevent the bolt from backing off on its own. I've started using this more often when there's a concern of vibration potentially doing the same thing over time. Works great!
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
I used Loctite. Twisted on by hand. My mount has a hex base, so removal should be easy.
Ford Bronco Applying Thread Tape to Dash Accessory Mounting Point? 20231209_130528
DirtyGSer
Jay
Massachusetts
'22 2D 6MT BD, '24 Edge, '17 Abarth, '23 Norden, '25 DAX
Use a jam nut screwed onto the thread b4 you instal then tighten the nut against the dash w/ a wrench.
BulletTheBronco
Hunter
Oklahoma
2023 Bronco
I put a o ring between the base and the mount and anywhere tension is used to secure the mount. This lets you have something to tighten to besides the metal/plastic and helps “grip” it. Has worked for me so far.
rcl4668
rcl4668
Pacific NW
Thanks! Is this just a rubber washer?
va011101
Andrew
Richmond, VA
2023 Bronco
I do not recommend the use of teflon tape for this application. Teflon tape is designed to allow pipe thread, which is tapered, to tighten to a leak-proof joint. Regular bolt threads are not tapered and the tape will not “lock” the joint. Use blue lock-tite or a lock nut of some kind.
rcl4668
rcl4668
Pacific NW
Thank you!
