APEX Valves on RTR wheels
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
Thanks for checking that, I was worried the stem would be too close to the rim and it would cause a problem since they don't flex.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Gonna air down SO FAST now
Yeah so about that..........Man, I go from 34psi to 19psi in 8 seconds. EIGHT seconds per wheel. That's insane. 100% recommend this to everyone.
SierraBronco
Right? It's no joke! Meanwhile four hose peeps are still untangling all their shit 😆
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Yup. I went from using individual chucks - to screw-on valves - to these. The amount of time saved is just crazy. But even with the chucks - I never saw the sense in taking out the whole hose system to deflate.....to inflate aboslutely :thumbsup:
K6V7N
Kevin
Riverside, California
2023 Bronco
Maybe call RTR and see how the wheels compare to factory Sasquatch wheels. We needed to use XL for ours.
Did you purchase the XL because of the beadlock? Would the standard valve work with the beauty ring?
SierraBronco
We needed XL due to the wheel itself, I believe. Shouldn’t be a problem with beauty ring
Dugout
Joel
ETX
24 Bronco
EZ Flate quick-connect chucks don't fit?
@SROC3 do you have any issue with your EZFlate chucks grabbing or snagging on your tire stems before (OEM STEMS) and after (APEX stems)
Mine snag when detaching. Just curious if I need to contact EZ or look for a better four tire hose. Thanks.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Hmmmm.....odd, mine (EZ FLATE quick-connect) "click" on easy and are only snagging a little now cause of them being super dirty. But when clean - no issues. NOTE - that when I had OEM stems they were not "anchored" and solid, since they have a rubber body. These valves are rock solid so when you push to click its never an issue.
