Apex-RCV with Sasquatch Wheels
Frankie945
Frank
Louisville KY
Q50
Want to share my experience with these Apex RCV valves. I’m 46 years old my knees are bad from dirt bike and skateboarding accidents when I was younger. I’ve been using a handheld deflator I got off amazon. It killed my knees having to stay squatted down while airing down each tire and it took a while to do so. I seen Apex had these RCV screw on valves but they were 100 bucks which I still think is a little too expensive but I broke down and finally got some a few months back and I’m glad I did because these have been a pleasure to use. They are so quick and easy to use.
Make sure you use a piece of sandpaper or sanding pad is what I used to sand down your oem valve stem to get any imperfections off of it so you will get a tight air seal. I had one that leaked when I first got them but that’s what I’d did wrong. Didn’t sand down the stem. Use a little blue lock tight also so they don’t spin off. This is an unlisted video. I didn’t get these for free or trying to market for them. I just think they are that good. Especially for the OEM Sasquatch wheel because they don’t stick out they fit perfectly. Also don’t loose the aluminum caps because I lost one and had to order some replacements but I got an extra just in case. They are little expensive too.
Ford Bronco Apex-RCV with Sasquatch Wheels IMG_2714
K6V7N
Kevin
Riverside, California
2023 Bronco
Did you purchase the standard length valve or the extra long length valve?
Frankie945
Frankie945
Frank
Louisville KY
Q50
The standard size. I’m not sure there was two options when I ordered. I’m usng the RCV Rapid Connect Valves.
K6V7N
Kevin
2023 Bronco
Thanks for the quick reply
can you post a few more pics from other angles so I can see how far they stick out beyond the beauty ring?
Thank you much!
Frankie945
Frankie945
Frank
Louisville KY
Q50
Thank you much!
I’ll get some tomorrow in the daylight. They work great with the Sasquatch wheels.
Gluestick
Josh
Nashville
instagram.com
That’s great - i ordered these for now and will switch to the complete xl valve stems on next tire change.
