Aonarch’s 2023 Bronco Build
MadMan4BamaNATL
Ray
Atlanta
Rear diff cover. :)
FP cover drain plug is awesome and even looks badass.
you should have an easier time installing it than I. :)
my small leak was from my failing to properly torque 1 bolt near the bottom. Follow that spec for sure.
Aonarch
Aonarch
North GA / MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
I double checked and even used a paint pen.
Aonarch
Aonarch
North GA / MT
SierraBronco
2022 Bronco
Aonarch
Aonarch
North GA / MT
Do they make a big difference?
So far yes.
They definitely provide more recline at the same setting.
They make the seat bottom less flat and cause you to be pressed into the back.
So far, so good.
I'll report back after some seat time.
Before installing them, I found the seats to be very comfortable. My only complaint was feeling like I was sitting at 90* on a bench or something. It was a comfortable bench, but still felt like that.
Aonarch
Aonarch
North GA / MT
Attempted tinting my Bronco myself. Did a pretty crap job 7/10 but it works.
Aonarch
Aonarch
North GA / MT
Put together the TrailRax rack. I did overhead press today at the gym so will wait till tomorrow or Friday to take the roof off to install the Pax Rack.
Then used the stickerfab vinyl on the grab handles. It's ok... not sure how well the adhesion will hold up. I did use their primer pen. Then I realized the forgot to get vinyl for the knee grab handle. The air vents I can live with, but the blue crap with the roast interior is AWFUL.
Then I installed the Mabett wireless charger.
One more upgrade
Joe Mogush
22 Tesla Plaid X 22 Escalade
Installed the Desert Does It Seat Jackers. I had them on my Jeep and they worked well.
I went with the single 3/8" shim.
I had to redo the installation, when I noticed on the product page it mentioned that they have a 1.5 degree slope.
The instructions didn't mention this and I didn't pay attention enough to notice a slope.
https://desertdoesit.com/collection...able-front-seat-jackers-2021-2022-ford-bronco
I have used the Desert Does It on a couple of vehicles; they make quality products. Currently using seat Jacker and mount for maglite under the front of my seat.
Aonarch
Aonarch
North GA / MT
Ford Bronco Aonarch’s 2023 Bronco Build PXL_20240425_214048637
Ford Bronco Aonarch’s 2023 Bronco Build PXL_20240425_214039748
Ford Bronco Aonarch’s 2023 Bronco Build PXL_20240425_212809682.MP
Ford Bronco Aonarch’s 2023 Bronco Build PXL_20240425_214056393
Installed the TrailRax with Pak Rax.
Install is straight forward but time consuming. I intentionally went slow and methodically.
You don't want to over tighten any, round off an allen, or snap a bolt.
Aonarch
Aonarch
North GA / MT
Installed the Inspired Overland Standard Lightweight Rooftop Tent.
If you are local distance to Gainesville, GA, check out Super Overland Outfitters.
