- First Name
- Bryan
- Joined
- Dec 4, 2022
- Threads
- 6
- Messages
- 216
- Reaction score
- 136
- Location
- California
- Vehicle(s)
- 2023 Badlands
- Your Bronco Model
- Badlands
- Thread starter
- #1
Did anyone installed the factory race series 3.0 internal bypass shocks on the bronco? i have a badlands sas and I'm thinking of changing the current suspension setup from sas to this, any idea or experience?
these are the info on fox website:
FOX Factory Race Series 3.0 Internal Bypass shocks for the Ford Bronco deliver position-sensitive damping technology, Dual Speed Compression (DSC) adjustment, and high-speed ready performance in a bolt-on kit.
Patented Internal Bypass technology allows for multiple zones of damping control. The result is a comfortable, confident ride with increased damping force through rough terrain. Internal bypass shocks produce more force progressively to control hard bottom-outs, prevent harsh top-outs, and provide an initial catch for landing. Shock fluid bypasses the main piston through a series of bleed holes in the ride zone. As the shock extends past the ride zone in rebound or compression, the bleed holes terminate, forcing fluid through the main piston.
Finned external reservoirs and aluminum shock bodies keep shock fluid temperatures cool for better performance. Type III anodization prevents corrosion and wear of the 3-inch diameter bodies. The DSC adjuster allows you to dial in your Bronco for load, environment, and driving style.
FOX Internal Bypass shocks deliver the support and confidence you need while driving high-speed through rugged terrain. Experience race-bred performance next time you leave the pavement.
2 Door | Without Sasquatch Package - 4.5" Lift
4 Door | Without Sasquatch Package - 4" Lift
2 Door | With Sasquatch Package - 3.5" Lift
4 Door | With Sasquatch Package - 3" Lift
If anyone installed it, can you please post a picture of it and how the bronco sits with the extra lift. Thanks
