Anyone Else Having Key Problems With Their 2021 Bronco ?
Pumpkinhead
Rochester, MI
2018 Ford Flex SEL
My 2021 Bronco Badlands 2 Door has been having trouble starting recently, with the "No Key Detected" message popping up as I sit in the driver's seat with my key in hand. I have been able to start it by using the remote start function instead... until yesterday, when it refused to start at all and locked the engine, windows, and power... and set off the alarm when I opened the door. I was stuck in a CVS parking lot- groceries melting- for over an hour before it agreed to start again. (I called Ford's Roadside Assistance and their only option was to send a tow truck... in 2-3 hours!)
I took the rig to my dealer- Dean Sellers Ford in Troy, Michigan- today, but their Service Department could find nothing and actually told me to "take a picture" if it happened again. (I asked what I was supposed to photograph and he actually said, "your hand holding both keys by the start button." I am not kidding!) Naturally, the car refused to start when I tried to leave their parking lot, at which point the service tech looked at the car from a few feet away, said that Ford had nothing online about this issue, but he would send an e-mail to their hot line... and then walked off. Fortunately, my great salesperson had introduced me to a manager, while I was waiting earlier, who showed me that you can lift up the mat in the center console storage area and place your key in a shallow indentation there, which is near the receiver. The Bronco started... but who wants to have to put their key inside the console to start their own $60k 4x4!
Am I the only unlucky Bronco owner to have experienced this frustrating problem?
Pumpkinhead
Pumpkinhead
Rochester, MI
2018 Ford Flex SEL
I tried the old school key on the door but did not use it to start the vehicle. Without an owner's manual, I wasn't sure how to remove the start button to access a manual lock, and my phone was almost dead and I couldn't find any info online. Even if I had, it would not solve the long-term problem of my #@$! key not working consistently. Thanks.
drew707
Ford Explorer
Did they even attempt to change the battery in the fob. I know it sounds like a weird thing since it’s new but in testing many vehicles have had weak batteries right out of the package leaving me and others fiddle-f’ing around to get to the key tray. I am sorry this happened though and the only backup is the location in the center console there is no other alternative
Massbronco
CHRIS
Massachusetts
Wrangler
If you switch to your 2nd key, does the problem still occur?
Bronco21fan
Angelo
NewJersey
In the center console if you lift up the mat there is a cut out to put the whole key fob inside of it to start the vehicle if the battery is dead in the fob
Scott R Nelson
Meridian, ID
They only problem I've had so far with my key fob is accidentally setting off the "alarm" when I have it in my pocket. :mad: It's happened three or four times so far and is embarrassing when I'm in a restaurant and it happens.
I prefer to just leave it in the Bronco and use the Keyless Entry Keypad to lock and unlock it. Don't know if that is a reasonable long term solution or not.
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
There's a Forscan fix for that. It changes it so 2 presses are required to set the alarm off.
stuckinohio
Columbus Ohio
2 Door Badlands, MT High 2 Dr, V6 Outer Banks, Lux
Mine occasionally will not recognize the FOB in the vehicle. But it's usually only for a few seconds then works fine. I have not tried switching batteries or retrieved the other FOB because it remedies itself.
Raptor911
Raptor911
Broadlands, VA
use a silicone key fob cover .. it takes alot to push the buttons by accident
Ford Bronco Anyone Else Having Key Problems With Their 2021 Bronco ? 1646962798223
BroncoB
Christine
Tampa Fl
Bronco First Edition
When was it built? There is a TSB for some of the earlier ones.
tsb 21-2251: "Some 2021 bronco vehicles built on or before 09-jul-2021 may exhibit an intermittent no key detected message"
Mine does it, built 7/1/21. I haven't had it looked at yet.
AK SNO RIDER
Ty
Alaska
Any idea what the TSB does to fix the issue? Mines built after that but has just started doing this. Sitting in the driver's seat and it pops the error. Clicking okay clears it but probably only a matter of time before it sticks.
stuckinohio
Columbus Ohio
Thank you for this. I was not aware.
ffdemoss
Northwest Arkansas
2009 F250, 2017 Fusion, 2014 Escape, 2005 LJ, 1968 M715
Built 9/30 and I've had one case of no key. Changed key fob battery just in case and no issue since. But it was definitely odd.
