Another Sta-Bar Disconnect Saga
BlancoBronco
Andrew
'22 Badlands
I'm looking for advice here about my 2022 Badlands (18,300 miles). While driving at low speed on flat asphalt, I got the Sta-Bar Disconnect warning some (many) of you have seen. I took it to my local dealer. It took them a few days to fix it. I picked it up and got the warning again five minutes into the drive home. I took it back to the dealer. They called to tell me the stabilizer bar and a few other parts need to be replaced, costing me $3,500 because the warranty is expired.
It seems to me that since the mileage is low and this is a known issue, Ford should step up. If I'd broken it, I'd pay to fix it without complaint, but this seems pretty clearly to be a factory defect to me.
How have you all resolved this?
BlancoBronco
Andrew
'22 Badlands
Fair point about the warranty. Perhaps my expectation that this very expensive vehicle should hold together as well as the Mazda I've been driving for ten years is misplaced, as is my expectation that Ford should take some responsibility for fixing known issues with its product.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
There were quite a few of us that realized the risk of the stabilizer bar disconnect - especially out of warranty. For those trims where it is integrated with the As Built profile, it can lead to the Bronco going into limp mode. Some might reasonably come to the conclusion that those trims out of warranty aren't worth the risk.
If your customer rating is highly rated, then Ford might extend a good will cost sharing solution. Otherwise, you might have some luck sourcing the parts from salvage.
GPPBronco
Detroit
linktr.ee
‘23 Toyota 4Runner TRD Off Road
Yes, I think that expectation is misplaced.
Ford Bronco Another Sta-Bar Disconnect Saga IMG_7111
CitrusBronco
Everglades
Citrus county, FL
Everglades
You should expect Ford to fix this, 3/36 or not.
18k miles to failure is unacceptable for this part.
I’d try to get Ford to take some responsibility on the repairs.
I don’t know if they will but you should expect this part to last much, much longer.
Good luck.
6GnPGH
Nathan
PGH
BL
I don't think the Mazda comparison fair. IE... How has the Stabalizer disconnected held up on your Mazda? Not trying to be rude, just make a point.
I get your frustration, these are expensive vehicles. I wish the warranty was years and mileage but it's either or.
I'd suggest kindly reaching out to the appropriate party (ask your dealer who that is), ask if they can do anything for you. It is out if warranty, they really don't have to do anything.
Good luck!
contented
Karl
Central Fl
BMW M2 Competition
Should it fail after 18k? Of course not. Would it upset me? Yes. 3 yrs/36k miles is what it is. If you’re an A list dealer customer, maybe they’ll help you, but it doesn’t sound like it. Aside from making certain the issue is properly diagnosed, I don’t see that you have much recourse.
Vehicles today, including our Broncos, are complicated rolling computers, purposely, IMHO, made harder and harder for mere mortals to repair.
Good luck.
RR25HB
Bob
Charleston SC
'25 Ford Bronco; '61 Chevrolet Corvette; '24 Hyundai Tucson
First you need a new technician. Fixed they said. You have to turn back around and they want to fire the parts cannon at it. They don’t know what the problem is.
Isn't the typical temporary warranty on a "fix" 90 days? FoMoCo needs to stand behind their fix and either: (a) fix at no cost; (b) burden share (subsidize) the cost to fix; or (c) fire their 💩 technician.
BlancoBronco
Andrew
'22 Badlands
I have to think this is correct. The tech initially diagnosed the problem as a sensor. It's hard to believe that he would have missed a damaged or broken stabilizer bar on the initial inspection.
BlancoBronco
Andrew
'22 Badlands
Good luck.
You ain't wrong, and I appreciate your empathy about this. I think there's about zero chance they diagnosed this correctly. It definitely seems like their logic is that if the simplest fix didn't work (replacing a censor), the next step is to replace the whole stabilizer bar system. This is like the doctor who prescribes aspirin for a sore knee on Monday but on Tuesday wants to amputate the leg.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Sway bar disconnect will leak and stop working. Or if the connector gets damaged stops working. No one to my knowledge has repaired a leaky one and got it to function.
The sway bar delete is coming, just need someone desperate enough to foot the bill for the experiment. May be a wiring harness change or a module change or both. I am pretty sure it's tied into the AWD Module as it's speed sensitive like the lockers.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I believe @BigMeatsBronco and @NorthShoreBronco worked out a way to remove the sway bar disconnect with a jumper to make the computer think it's there.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
