Another Broken Axle / CV Joint
BlueBronco
DFW
The bushing prevents the axle from separating.
For people that want big fat heavy tires, order the right build from the factory. These are too expensive to void the warranty this early!
Again, did you watch the video? The bushing has nothing to do with the cv axle.
Lurker B6G
Murph
Cleveland, OH
Ford Explorer Timberline
For everyone looking at this objectively:
1) The OP added a RC 2 inch lift kit. This kit has a 1.6 inch front spacer, and a 1.6 inch rear spacer (we will only look at the front).
2) The net effect of the front of the vehicle was to push it up 1.6 inches x 1.47 (my take on the front arm ratio). This raised the front end by 2.35 inches.
3) The first 0.55 inches of lift would have put the CV angle in line with a stock BL.
4) The first 1.15 inches of lift would have put the CV angle in line with a SAS/WT.
5) The OP added 1.2 inches of lift to what the SAS/WT has. No 210 front end, and added 35" tires.
If that last 1.2 inches of droop is what buggered his system, then the tolerances are very tight with regard to any kind of standard lifting. Something like 1.2 inch max for Base, BB, BD, OBX. Perhaps the 210 can handle more CV angle, but I doubt it - just more abuse.
However, there are more dead 2.7 liter engine stories than busted CV stories, and engines are made with excellent failure metrics, so this gives me some hope...Fingers crossed that this was pre-existing or operator error (no offence to the OP).
King Luis
Toronto
Volvo XC60 & MK5 Jetta TDI
0.78 inch difference in the m210 axles. also the m210 has 1500nm more torque capacity.
i know the pic shows the m220 but you can see theres a difference. and 1500nm of torque is about 1100ft lbs of torque which is quite a difference.
Ford Bronco Another Broken Axle / CV Joint 1642623042512
Ford Bronco Another Broken Axle / CV Joint 1642623050592
https://www.therangerstation.com/ranger-tech/dana-advantek-axles-ford-ranger/
now i'm not saying the OP's axle should have broke so easily, but a reason why the larger wheels and tires get a larger axle.
Jim Walter
Athens Ga
2015 JKU
Just one of the many reasons I went with Badlands and Sasquatch package. No warranty issues with after market lifts. However it is very disconcerting to hear about any axle failures on a lifted Bronco. I have installed after market lift kits on all my Jeeps, mostly long arm, without any axle failures on a solid axle. Guess IFS really is a different bird.
Efthreeoh
Hummer H3T
What if... the axle was just defective from the and... broke?
Pilsner
JTR, 81 Bronco, 21 BD
As all of you know, there are many ways to make a vehicle taller. Bigger Tires, Body Lift, Coil-over spacer, the deluxe, most expensive is to drop the driveline. This method changes the CV angle and needs correction. For all but the driveline drop, CV and steering link angles will be exactly the same at the new ride height. That said, at full drop on a trail, the tire will drop 2" further and will change the angle. (assuming nothing else is limiting the drop, such as stops on the upper control arm, as is the case with GM 3/4 ton)
With all due respect, you clearly have no idea what you are taking about.
Pilsner
Part of cheap spacer lifts, and any lift in general, is reduced lifespan of CVs. It just is. Don’t expect Ford to replace at their expense, even if there was an issue from the factory. You pay to play. Either upgrade CVs or pay for direct replacements. Personally I’d upgrade myself instead of paying Ford to put the same ones in there.
this is nothing a very seasoned 4wd person doesn’t already know.
Yep. More angle, more stress. More droop can over extend them and pull them apart. Diff drop is not ideal either. Best solution is suspension lift, possibly UCA's, and upgraded CV's. That's not counting steering/ tie rods.
ryridesmotox
Ryan
Murrieta, California
21 Bronco Black Diamond
FifthCard
Allen
US
Jeep Wrangler Rubicon
If you couldn’t get a Bronco out of gravel driveway hole, it was broke before you started trying. And this is why I went SAS from the get-go. Warranties for 35’s. I’ll likely do the same with the Ford Performance tune. It’s a $50k+, very capable warrantied vehicle out the door. It becomes a toy once the warranty is up and it has 70k miles on it. Patience is a virtue.
Good luck though, I’ve seen some crazy stuff fixed on manufacturer’s dimes after non-factory mods.
Yup.. Like you I got the badlands with SaS and plan to do what I can in the stock configuration. I will add things to it like air compressor and swap out rock sliders per haps and then even add in Broncbuster tie-rod and steering improvements but aside from that I have already had a blast wheelin the way it is.
Bing
Brad
Bloomfield Hills
2022 Black Diamond
Interesting thread, I just came back from an off-road weekend in Northern MIchigan this afternoon.
Similar experience. I backed out of some mud and snow in 4WD - seriously, absolutely nothing extensive here. Then click, click, click’. Had my buddy trailer me back home 2hrs as I had a cyclical clank on the driver side, 30 mins into the weekend. Big bummer.
I’m guessing CV Axle is def busted. I’ve also added 34.5 tires and a 2” spring lift - 3,330 miles. I’m sure I’ll lose the warranty argument.
Sorry to hear about the issues…you’re not alone.
rtazz17
Connecticut
2022 Ford bronco big bend
Its a very doable replacement in your garage if your dealer says no. Took me 4 hours. Not a hard job at all… but if its your diff then thats above my pay grade without a lift in my garage. Pia without.
im always worried when in reverse in 4wd. Bad things seem to happen. Idk why
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
I am assuming you have the M190, it is was a big jump in tire size over stock 31 inch tires. Similar if you added 39” tires to a SAS. Putting a lot of stress on components
kodiakisland
Arkansas
Late to the party, but of course a spacer lift sucks.
Anyway, was this the first time you used 4wd after the lift? Most likely you, or whoever you paid, pulled the CV out while installing and that’s what caused the failure.
I’ve put my CVs at some extreme angles in some gnarley stuff without breaking them. Yours had something wrong to begin with and my money is on installation error of the spacers. I’ll bet you or whoever did it removed the axle hub and spindle instead of the rear of the LCA.
Edit to add just noticed this was a year old thread someone just resurrected 🤷🏻‍♂️🤷🏻‍♂️🤷🏻‍♂️
OP hasn’t been seen in a year.
