- First Name
- Karl
- Joined
- Nov 26, 2021
- Threads
- 28
- Messages
- 722
- Reaction score
- 1,666
- Location
- Central Fl
- Vehicle(s)
- BMW M2 Competition
- Your Bronco Model
- Badlands
I've seen so many build threads adding lifts and bigger tires. Seems everyone does it, right? Originally intended to do the same when we ordered an outer banks w/o sas. But after much fussing and fretting about this very topic, we changed our order to a badlands w/ sasquatch. Everything is designed to work together including not only drive shafts, cv joints, axles, axle ratios, 35" tires, etc but also abs, traction control, emergency braking and so forth. And full warranty.
I spent a fair amount of time researching this topic on Jeep threads. Horror stories abound. My take on the bottom line was, if you're going to lift, do it right (costly) and even then, things will wear out much faster. It seemed to be an accepted and expensive fact of life.
To me, the OP is a cautionary tale. I'm staying stock.
