- Joined
- Jan 10, 2022
- Threads
- 2
- Messages
- 25
- Reaction score
- 41
- Location
- Roswell GA
- Vehicle(s)
- 2021 Ford Bronco
- Your Bronco Model
- Big Bend
- Thread starter
- #76
The part link you provide appears to be for an AWD Bronco Sport. Which brings up a good point. What a crazy/confusing naming convention for the Bronco. It's the most confusing of any series of all time. What is the correct term for new Bronco? Dealerships say "you mean The "Big" Bronco". Any way, If I type in my wife's VIN to provided link, I get no parts.It has been written about on this forum already, but if you want to look through fords part system yourself you can. This is a pretty easy to navigate link https://parts.lakelandford.com/p/Fo...rol-Arm-Front--Lower/105745267/MB3Z3079A.html.
The spring/shock is different and the axle housing is different with SAS. The steering rack also has different part numbers, but all other components are the SAME. Same part numbers for arms and axles.
Edit: After some more digging, it looks like I was wrong. It appears that there was some media release that claimed that all axle shafts were the same that was repeated here, but they do have different part numbers.
So it looks like the control arms are the same between models, but rack, axles, and half shafts do change.
