Ammo Can for Compressor
NVCowboy
William
Henderson, NV
I just purchased one of these:
Ford Bronco Ammo Can for Compressor 20231011_180308
It needs to remain portable so I can throw it in the superduty when we're out in my wife's trailer (that's what I call the RV now that the cargo conversion (my trailer) is done).
I have this laying around:
Ford Bronco Ammo Can for Compressor 20231012_160313
The carrying bag that came with the pump is pure Chinesium. I can mount the pump inside the box. Before I go through the effort, is there a downside I'm not seeing? Yes, I know I have to leave the lid off while I'm running the pump.
KABQ
Aaron
Albuquerque, NM
The only thing I can think of as a downside is cooling.
It might also sound really annoying.
NVCowboy
William
Henderson, NV
Lol. Thanks. I figured it'd vent okay with the lid off. Now the echo chamber you're describing . . . Take the bottom plate off and run it in the box before drilling and mounting; check.
j_marinelli
Spring Branch, TX.
Imonamoose
Moose
Earth
Truck
A little birdie told me that Thors Lightnig is coming out with a pelican version of their product.
Not affiliated, but those guys are a bunch of awesome retired LEOs and Vets making solid American made products.
Tricky Mike
21 Bronco
These compressors run very hot, my only concern would be reduced airflow to the cooling fins. With the lid off it should be minimal though.
NVCowboy
William
Henderson, NV
Yes, that would worry me more if the fins weren’t at the top of the compressor, closest to the opening.
Gtrekker
Gary
The Air Armor is a single lung compressor. I imagine you checked the dual lung conpressor will fit in the box.
Like its been said above... Heat is a big thing with compressors. "Hot on Contact" so be mindful handling the ammo box when done...
Safety First :sneaky:
sprk33
Tampa FL
2023 Bronco WildTrak
I have this and it works awesome. I had a jeep prior to the bronco and used it several times after I aired down on the trail.
NVCowboy
William
Henderson, NV
I started to get a little ocd about the uneven bottom once I bolted it in the box. Rubber feet on the bottom of the box. Duh! OCD+OCD=perfect (This time).
Fonz54
Lou
Monterey, CA
Jeep Commander, Porsche Cayenne, Mercedes C250
NVCowboy
William
Henderson, NV
Why not pickup one of those canvas tool bags from Harbor freight? You can keep a mess of other stuff in one of those. Obviously you would have to take the compressor out while using it. I use these bags for lots of my tools and goodies.
https://www.harborfreight.com/tool-...bags/16-in-tool-bag-with-6-pockets-63637.html
Yeah, I have a yard sale craftsman bag that might work. I'm only using it for the drill I use to raise and lower the cargo trailer tongue jack. Why not just, indeed. KISS.
NVCowboy
William
Henderson, NV
Ford Bronco Ammo Can for Compressor 20231013_155721
This will certainly work better for now.
