Air conditioner issues, 2021 Big Bend
Gilligan390
Ryan
Equinox
I am having significant air conditioner issues and wondering if anyone else has encountered the same. It started a year ago when they changed out the compressor due to the vehicle blowing hot air when the air conditioner is running.. I brought it back in several months later for the same reason, and there was a couple Small leaks. Now they cannot find the problem.
The car will intermittently just run ambient air when the air conditioner is on. Whatever the outside temperature is, that’s what the air blows. I would say this occurs more than cold air blows out. Sometimes cold air will blow out for two or three days and then it resort back to you the outside temperature air. Living in Phoenix it’s not fun.
Has anybody encountered anything like this and have they been able to diagnose it? I’ve taken it to the shop twice recently and they cannot find a problem.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Sounds like is low on Freon. I haven’t had any issues. Or heard of others with the same symptoms
frdfan
Greg
LaVista Nebraska
22 BB Sasquatch HPRM
No issues here, I run mine on "Auto" with the temps set to 68. The "Auto" setting puts it into a recirc mode so it doesn't draw in outside air...maybe give that a try.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Ryan. Can you send us a DM with your VIN and dealership info? I can look into this for you.
thesocalexplorer
Southern California
Sounds like a your compressor is cycling excessively. Do you notice this happening after heavier acceleration? Some have noticed that the AC "pauses" when engine load is higher.
My A/C has been solid. Colder than any of the Toyota products I've owned previously, which was my previous gold standard.
iamcris
Cristian
Lakewood, WA
21 Bronco Badlands
Some basics. Ensure condensor fins are clean and free of obstruction (limiting air flow). Ensure cabin air filter is clean (dirty will obstruct air flow over the evaporator coils). Also ensure there's not too much pag oil in the system.
FoxFour281
Kelly
Central Valley, CA
02 Mustang GT, 02 Expedition EB
Low freon will cause the compressor to cycle frequently. Did the dealer ever mention about putting dye into the system for leak check?
Unrelated to a compressor replacement, but I had to have the air control modular reprogrammed because it would not always turn on the compressor. Having it set to full cold or hot was the only to make a change in air temp.
Barneyridesagain
Deep in the heart of
'22 Bronco, '20 Trail Boss, '18 Triumph Tiger
We are having the same issue. AC works great from a cold start. Gradually fades after vehicle has been driven a while. Acts like the compressor is short cycling but can’t tell for sure when going down the road. Eventually gets to where there is less than a 10deg split on return and supply. Saw a post about issues with the pressure transducer but can’t find it now.
GToddC5
Todd
South Jersey
www.bronco6g.com
I picked up my Bronco in January, so I didn't know the AC didn't work until a stupidly hot day in May. I was afraid to take it to the dealer for fear of it sitting there forever, no loaners, tearing the dash apart, etc. Finally one day a long while later, I discovered the compressor doesn't work . . . unless of course it's plugged in. Yep, they never plugged it in. Check the plug, and any related plugs, as it could be something stupidly obvious that they even missed the second time.
dgorsett
colorado
F250, Mustang, Explorer
Since OP said "Sometimes cold air will blow out for two or three days and then it resort back to you the outside temperature air." It has to be something controlling compressor function is not working, sounds like coolant and the compressor itself are fine. Definitely a job for the dealer to diagnose a compressor control issue (BCM?)
Ford Motor Company
Dearborn
Poul28
Caleb
Las Vegas
I'm having the same problem now and I live in Vegas. So I'm with you on the heat part. Did they find the problem?
Ford Motor Company
Dearborn
Can you look into mine as well?
Good afternoon, Caleb. Would you please send over a private message with your VIN and dealer info so I can look into this concern with your air conditioner?
